Spring question
Old Oct 31, 2003 | 02:50 PM
Munky's Avatar
Munky
Default Spring question
I just noticed that my 68 might have a slight lean toward the drivers side when looking at it from the rear.
Myinital thought is a the leaf spring. Am I on the right track? Also, how difficult is it to replace the rear spring?
Thanks.
Old Oct 31, 2003 | 03:50 PM
72GACRZR's Avatar
72GACRZR
Default Re: Spring question (Munky)
Some say easy and some say PITA. Do a search in the archives on rear spring and you will get two pages of responses. The lean could be a number of things, perfectly normal, body mounts, springs, etc. I don't think very many of the C3s are sitting perfectly level. If the rear spring is bad, you are suppose to be abe to measure the wheel well lips and get a 1-2 inch difference between one side over the other.
http://forums.corvetteforum.com/zerosearch
This dosen't leave what I found, but put "rear spring" , "C3" and "archives" in the blanks and you should get the results.
Modified by 72GACRZR, 3:51 PM 10/31/2003]
[Modified by 72GACRZR, 3:53 PM 10/31/2003]
Old Oct 31, 2003 | 07:29 PM
Dk Met Grn 80 L82's Avatar
Dk Met Grn 80 L82
Default Re: Spring question (72GACRZR)
Same thing just happened to mine during the last 3 months. I was planning to change the old spring for piece of mind, now it is next on the list.
Old Oct 31, 2003 | 08:44 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
My drivers rear is about 1" lower than the passenger side. I'll be changing my rear steel spring out with a TRW 340# composite in a few weeks. I'll update my findings.
Old Nov 1, 2003 | 05:07 AM
hunt4cleanair's Avatar
hunt4cleanair
[QUOTE]I just noticed that my 68 might have a slight lean toward the drivers side when looking at it from the rear. QUOTE]
The AIMs for late model C3s specified three different length link bolts for factory workers to use and adjust those heights to get it level and into specs. A temporary option could be to change link bolts...shorter one side...longer on the other. Or, even measure to see if they are a different length. The length differences were not dramatic.
As indicated...its a PITA! Must support differential while dropping spring.
To Spring question
