Attention, those with frame/a-arm structural damage
Old Nov 7, 2003 | 04:09 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Attention, those with frame/a-arm structural damage (Kevin_73)
Kevin, you're right, it was WPEdirect. I did to look him up and see what kind of pictures he has.
71 roadster, that's a great picture, thanks! That basically looks like the identical failure that aaron_74 had. The repair looks to be adequate.
Anymore pics?
Old Nov 7, 2003 | 09:48 PM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
Default Re: Attention, those with frame/a-arm structural damage (burners)
Here is the thread, and the pics are still up. http://forums.corvetteforum.com/zerothread?id=590922
Old Nov 10, 2003 | 10:55 AM
burners's Avatar
burners
Cruise-In V Veteran
Hey thanks, Kevin. That's the one I was thinking of. Now if I can only get a hold of aaron_74 to see if he has anymore pictures.
Old Nov 13, 2003 | 01:06 PM
burners's Avatar
burners
Cruise-In V Veteran
Does anyone else have anything to add? I would like to see more pictures if they are available.
Old Nov 13, 2003 | 01:41 PM
WPEDirect's Avatar
WPEDirect
Don't have the original pics anymore, and the damage has been fixed. I hope the 'net pics are good enough for you. Thanks! :conehead
Old Nov 13, 2003 | 02:22 PM
Wrencher's Avatar
Wrencher
I've posted on this subject a few times with a fix I use on customer cars. Mine is fine but eventually I will reinforce my frame as well with the plate that I manufacture and weld in. The one sure fix is the upper control arm cross-brace that eliminates the flex in the forward frame area. I'll e-mail a picture of the template to those that want it.
Hans
Old Nov 13, 2003 | 03:07 PM
burners's Avatar
burners
Cruise-In V Veteran
Default Re: Attention, those with frame/a-arm structural damage (WPEDirect)
WPEDirect, thanks those pictures are fine. Can you tell me more about your car? What springs are you running and what's the mileage? Do you think the car was ever involved with any previous front end damage?
Wrencher, can you e-mail me that info? I would be interested to see what you have done. eric@speeddirect.com
Old Nov 13, 2003 | 06:15 PM
Wrencher's Avatar
Wrencher
Sure. First thing in the AM as I am out the door...
Hans
Old Nov 14, 2003 | 01:54 PM
Thumper76's Avatar
Thumper76
Default Re: Attention, those with frame/a-arm structural damage (Wrencher)
My 76 had the welds break on the front passenger lower A-arm mount. Didn't cause any damage and was easily re-welded. Is this a common problem? :confused:
Old Nov 14, 2003 | 02:09 PM
Wrencher's Avatar
Wrencher
Default Re: Attention, those with frame/a-arm structural damage (Thumper76)
Very common, especially with grippy, wide rubber or if you live in an area with lots of rough roads.
Hans
Old Nov 14, 2003 | 02:17 PM
burners's Avatar
burners
Cruise-In V Veteran
Thanks, Wrencher for the e-mail. So that's basically a doubler plate for the forward part of the frame. Good idea.
Thumper76, it does, indeed seem to be a common problem. In general, the lower a-arm mount appears to be weak. Especially after many years and many miles.
Old Nov 14, 2003 | 02:23 PM
Wrencher's Avatar
Wrencher
That's correct. That's the flex point without the spreader bar. The doubler spreads the stress across a wide enough area to prevent the initial tear. Also, unbeknownst to most, that little steel block with the two theaded holes is sharp like a razor on the inner edge. If one does nothing else, just removing it and rounding the contact edges will help prevent the tear from starting.
Hans
Old Nov 14, 2003 | 03:51 PM
  #33
burners's Avatar
burners
Cruise-In V Veteran
Good point about the sharp edge on the steel block. Also, the stiffening ribs that are in the stock frame create a stress riser on the inside of each rib near the end of the steel block. I think that the block is too small. That load needs to be distributed over a larger area.
Old Nov 14, 2003 | 08:03 PM
  #34
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
about 10 years ago my frame was cracked on the inside rail in the area of the power steering pump. Had it professionally welded by Bear Alignment in Denver.
I have also always had problems where the passenger side lower a arm rear mounting bracket attaches to the frame. It has always tried to pull away since the car was about 5 years old in 80. Had it welded professionally but it pulled apart again several years ago. Then I finally got the welder out and welded the crap out of it building a lot of material on it and it has been holding up since then.
Also both upper spring pockets are currently cracked a few inches.
[Modified by turtlevette, 8:16 PM 11/14/2003]
Old Nov 18, 2003 | 11:07 AM
  #35
burners's Avatar
burners
Cruise-In V Veteran
Default Re: Attention, those with frame/a-arm structural damage (turtlevette)
turtlevette, can you get me some pictures of those areas. Especially where the current cracks in the spring pockets? Also, what rate springs are you running and what is your mileage?
