Keisler 6 spd or 5 spd.
What are the pros and cons of each?
I am currently running a small block Fast Burn 385, 4-spd.
Thanks, Eric.
sorry It could be sooner
EDIT: I just called Kessler. unfortunally my tranny will not take 6 to 8 weeks, Instead it will take 12 WEEKS! aarrg. well I may get the carpanted before it arrives
[Modified by 71'AirStrike, 10:59 PM 11/4/2003]
In my opinion:
Pros - 6 speeds, higher power rating
Cons - higher price, higher first gear, requres slight modification to crossmember
I'll probably stick with my original unit (it's due in two weeks), but I would have given real strong consideration to the six speed if I would have known about it this summer.
Good luck -
Another important consideration is horse power, if you plan to exceed 475 hp then the 650 horse 5 speed only has a 17 percent od which doesn't justify the expense of the swap. So If youwere planning to go with over 475 horses. I would lean toward the 6 speed.
If you have a numbers matching car another consideration is originality if you go with the 5 speed kit you can go back to stock anytime you wish, but with the 6 speed kit, you must cut the front lip on the tranny tunnel, and I believe elongate the hole in the floor very slightly. I went to keisler's and saw the installation on a 79, which I was told by one of keisler's mechanics has a smaller tranny tunnel than my 74 which I would assume is the same as your 69, but I don't know for sure.
I would also like to suggest one other idea. It is not on the website yet but mine is being built as we speak, I will be getting a 650 horse kit with a .8 5th and a .62 6th. I realize that sounds insane at first, but at some point I plan to run over 600 hp so I needed more than the 475 hp kit. I also like carbs and agressive cam profiles which means my motor will not make most of its power down low in that 1500 rpm area. I know the fastburn makes more torque than my 350 , but I still believe it will be in a bind trying to push your 3200 pound car down the freeway at 2500 rpm at 98 mph, or 137 at 3500 (with 27" tires and 4.11 rear http://www.keislerauto.com/gm/transm...68-82_6spd.asp ). I had a th 400 in the car before and got much better gas milage at 70mph/2800rpm than at 40/1800. But to be honest the biggest reason is the car is more fun to drive the longer you keep it in the rpm band.
I would also like to encourage you to call Keisler and get a few numbers of satisfied customers. I did this and it made me feel much better about the money I was about to spend.
I hope this has been helpful. I am sorry it is so long. Email me any questions, I have been sick and am bored out of my mind so it's no trouble,
It should do fine behind my FastBurn as the future plans call for a bit more aggressive cam on a tighter lobe center and EFI. I would be happy with 450 hp at the crank. Of course I will never really know as the car will be chassis dynoed, and I am not pulling that engine out again! (Hopefully!).
Thanks for the suggestions,
Eric.
[Modified by EricU, 10:41 PM 11/3/2003]
I bought my transmission from Mike Forte in MA. He mods the Tremec for the GM application and the only mod I had to do was the shifter.
Tremec:
Modded :
For a handle, I just had the shop that welded the shifter up cut my old Hurst down in size and redrilled it for new bolts.
I used a mount from BowTie Overdrives that looks just like the one Keisler sells and had a driveshaft made locally. The only reservation I have about the Keisler setup is that it seems to have a one piece yoke at the tranny and I will say from experience that it is a lot easier to install the drive shaft if the yoke comes apart at the tranny.
FYI. My total cost was about $2200 for the equivalent of the Keisler kit. The Keisler setup wasn't available back then but looks pretty nice if you want it all in one piece.
[Modified by SteveG75, 11:19 PM 11/3/2003]
:D Both but as stated the TKOII only offers a .8x overdrive, hardly worth switching from a muncie for.
