Engine Compartment Cleanup
Old Oct 31, 2003 | 07:55 PM
Dk Met Grn 80 L82's Avatar
Dk Met Grn 80 L82
Default Engine Compartment Cleanup
My engine is still original. One of these days it will get freshend or ZZ4. Until then my engine compartment is looking its age. What can be done to clean up the appearance with the engine still in? I've cleaned most everything with simple green. Can painting be done? Can the exhaust manifolds be painted with that grey stuff while still in place? Power brake booster? master brake cycl?
Old Oct 31, 2003 | 10:27 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Engine Compartment Cleanup (Dk Met Grn 80 L82)
just mask off sections you don't want painted and go at it. Make sure to throughly cover the fenders, doors, windshield, hood - etc.
Use some semi gloss or chassis black for the suspension and chassis.
It is easier to wait until the motor is pulled, but with a little work it can be done with the motor in.
Old Oct 31, 2003 | 10:47 PM
standup's Avatar
standup
........Can the exhaust manifolds be painted with that grey stuff while still in place?
That gray stuff is either manifold dressing, Eastwoods Cast Blast or POR 15....probably easier if you take the manifolds off so you can remove any oil or loose rust before you coat them.......
Old Nov 1, 2003 | 10:17 PM
Dk Met Grn 80 L82
Default Re: Engine Compartment Cleanup (BSeery)
Thanks for the input. I'll give it a try.
To Engine Compartment Cleanup
