wiper door ???????
Old Nov 1, 2003 | 10:26 AM
Michael Bell's Avatar
Michael Bell
Default wiper door ???????
The wiper door on my 69 is hung up on the blade how do you open this manually? Chiltons has nothing on how to time wipers :withstupid:
Old Nov 1, 2003 | 10:38 AM
Surfer69's Avatar
Surfer69
Default Re: wiper door ??????? (Michael Bell)
Welcome! I have a post on problem with door also, but for you just pull up and fwd by hand and it should open.
Old Nov 1, 2003 | 10:51 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Easiest way IMHO is to remove the rubber plug from the end of the vacuum can under the hood on the passengers side. Then, put a big phillips screwdriver, or better yet a socket wrench extension in the hole. Push the diaphragm in. This will open the wiper door with less chance of bending or breaking something. Chuck
Old Nov 1, 2003 | 12:09 PM
theandies's Avatar
theandies
Default Re: wiper door ??????? (Chuck Gongloff)
That is the best way to manually open the door and it is how the owners manual says to do it in case of failure. :iagree:
To wiper door ???????
