Installing a new dist hold down.
Old Nov 3, 2003 | 02:18 AM
Shark Racer's Avatar
Shark Racer
Default Installing a new dist hold down.
Dumb question. The bolt that holds the distributor in place... should I seal that? I got an aluminum hold down that looks real pretty. ;) How far should I snug it down? It has an allen head stud to put in the intake and a nut to tighten down the bracket.
Thanks for any help...
-Steve
Old Nov 3, 2003 | 03:33 AM
1979toy's Avatar
1979toy
Default Re: Installing a new dist hold down. (Pacin'California)
You may want to put some Loc-tite on the stud but there is no need to seal it, the hole does not go all the way into the manifold.
Old Nov 3, 2003 | 06:42 AM
guppie's Avatar
guppie
St. Jude Donor '08
Default Re: Installing a new dist hold down. (1979toy)
:iagree: Only make sure IT IS NOT!!! the red or you'll never get it out. Blue works nice on items like that. :cheers:
Old Nov 3, 2003 | 07:44 AM
zymurgist's Avatar
zymurgist
I used a Mr. Gasket stud/chrome hold-down on mine. The manifold hole is definitely blind. I only used a dab of anti-seize on it and screwed it in place. With this system, the hold down is retained by a nut on top of the stud.
The reason I used the anti-seize was that I might want to remove it at some point. The stud is steel and the manifold is aluminum, without Heli-Coil inserts (it was brand new when I installed it). I don't trust aluminum threads.
[Modified by zymurgist, 7:46 AM 11/3/2003]
To Installing a new dist hold down.
