2nd post: AIR pump removal
Old Nov 4, 2003 | 02:20 PM
HDFLH67's Avatar
HDFLH67
Default 2nd post: AIR pump removal
Sorry to repost, but I'm really hoping for a knowledgeable response ASAP>>>
I am replacing the original '75 exhaust with a set of duals. I will need to remove the A.I.R. pump since there is no connection for it to the new pipe, along with the heat riser valve. Can I just plug the vacuum lines that are currently connecting these to the carb and thermostat housing?
I can't find any tech references to doing this; any knowledgeable advice greatly appreciated!
Old Nov 4, 2003 | 10:35 PM
trw's Avatar
trw
Default Re: 2nd post: AIR pump removal (HDFLH67)
Yes.
The Feds might not like it. But no engine problems.
Terry
Old Nov 4, 2003 | 11:06 PM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
As stated above, yes, you can just plug the lines. Also note, there are small tubes inside of the manifold that should be removed before plugging the manifold. Of course, if you're installing headers, it won't matter.
I submitted a tech tip for removing the injector tubes without removing the manifolds. I'll copy and paste it below:
I have some advice on pulling out the tubes that are inside
the manifold without having to remove the manifolds. You will need a
fairly strong, yet thin wire (coat hanger is almost too thick).
Bend a very tight 'U' in the end of the wire, with the distance from
the bottom of the U to the short tip (as well as the width of the U) being
less than a quarter inch.
Now,
feed the 'U' end of the wire into the holes in the manifold and try
to locate the holes in the tubes. The holes are square and usually one is
on top and the other on the bottom. After you feel the wire get into the
hole, tug and the tube should pop out. Worked like a charm for me. The
square holes in the tubes are about 1/4" x 1/4".
After
pulling out the tubes, find the correct size pipe plug for the holes in
the manifold (I took the exterior tubes with nuts on them into Autozone
and they found the correct size plug). The pipe plugs were tightened with
an allen wrench.
Old Nov 4, 2003 | 11:27 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Re: 2nd post: AIR pump removal (Captain Morgan)
***Also note, there are small tubes inside of the manifold that should be removed before plugging the manifold.
This will not apply to '75 & '76 Corvettes as they have a single plastic/rubber A.I.R. hose coming from the pump to a "welded nipple" just below the heat riser. The '75 & '76 A.I.R. manifolds are like a '74 L-48 Automatic Federal Emission car with bosses that are NOT DRILLED because of the previously mentioned reason. Actually, these two years('75 & '76)are the EASIEST to remove the smog set-up. You can also remove that "third pulley" off of the double pulley(it just stacks on)for a "cleaner" look.
Old Nov 5, 2003 | 12:44 AM
HomeboyMI's Avatar
HomeboyMI
I did this to my 75 Convertible about 16 years ago. I use mine as a daily driver. I have logged about 75,000 miles since I disconected the AIR pump and put on duels. I was surprised that I didn't get better gas mileage.
No problems and there is nothing in your exhaust manifold that I ever heard of until now. I had a metal tube going from the exhaust pipe (welded on) to the AIR pump. Just eliminated it. Car runs as new without any trouble.
Also seems to go faster. MPG 16-17
Old Nov 5, 2003 | 02:25 PM
Captain Morgan
Cruise-In V Veteran
Default Re: 2nd post: AIR pump removal (Paul Borowski)
Thanks for the info Paul, I was unaware of the differences. :cheers:
Old Nov 5, 2003 | 10:56 PM
HDFLH67's Avatar
HDFLH67
Thanks to all for your input! I feel much more confident about what I'm doing now!
To 2nd post: AIR pump removal
