ok...im getting ready to install my new cam....im to the harmonic balencer.....now the pulley that is connected to the crank...how do i get that off? cause i dont think the harmonic balencer can come off with that still on? if i was to try and losen the bolt it would turn the motor and not losen the bolt at all.....any suggestions please?
thanks
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Re: i need help please!! (Ebbsvette)
The crank pulley should be held by 3 bolts. Loosen those three bolts and take the pulley off of the harmonic balancer. You will then need to loosen the bolt that holds the balancer on the crank. Leave the plugs in the heads, the compression will help keep the motor from turning. Then use a puller to get the balancer off the crank.
welp...problem to both of those...hehe....heads are off the motor.....car is an auto (but its on blocks anyways) what i think im gonna do is get some really strong bolts and put them into the holes on the pulley and using a crow bar between them so they dont move and using a breaker bar to losen the nut....the bolts should keep the motor from turning.....hopefully...
thanks
That should work. Make sure you pry the balancer off. Use a puller.
thanks for all the advice guys.....the new cam and lifters have been installed wooo now im just waiting on my gasket set and my motor will be complete.......for now :reddevil
