amp gauge for 1976
Old Nov 7, 2003 | 05:07 AM
geoff4961's Avatar
geoff4961
Default amp gauge for 1976
i just got the car and have been working on different projects and the amp gauge does not work. Does anyone have any surgestions short of buying a new one.
Thanks Geoff
Old Nov 7, 2003 | 01:08 PM
markdtn's Avatar
markdtn
Default Re: amp gauge for 1976 (geoff4961)
Buy a used one?
If you don't care to know charging condition, you can hook the 2 wires together and it should operate the car fine.
Old Nov 7, 2003 | 03:13 PM
Fang S-289's Avatar
Fang S-289
Thanks Geoff
When you say it does not work, do you mean the needle doesn't move or is there a different manifestation that leads you to believe it's defective? The needle on mine doesn't move much, if at all, but I'm not sure that means it's bad. :skep:
Old Nov 7, 2003 | 06:17 PM
JOliver's Avatar
JOliver
Default Re: amp gauge for 1976 (Fang S-289)
If the needle moves .as in its reading something (not moving from just vibrations) The gauge is fine...These gauges burn very easily if its smoked buying a new or used is about yoru only option.
Email me I know where plenty are
Jason
VetteInsrtuments@aol.com
Old Nov 10, 2003 | 09:14 AM
THEWIZARD's Avatar
THEWIZARD
4th Gear
If the needle is OK, it could be a simple fix.
Often the wire from the coil is burned.
You can fix this by dismantling the gauge and replacing the copper insulated wire which is forming the coil.
You have to look for the same wire thickness in for example an old junk transformer, and wind it in the same maner as the old wire, then strip the ends with a lighter or something and solder it back in place.
Konstant
To amp gauge for 1976
