TIRE PRESSURE?
Old Nov 7, 2003 | 11:09 AM
twoinchgroup52's Avatar
twoinchgroup52
Default TIRE PRESSURE?
WHAT IS THE PROPER TIRE PRESSURE FOR THE ORIGINAL TIRES ON THE 82 CE?
THANKS.
Old Nov 7, 2003 | 11:15 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: TIRE PRESSURE? (twoinchgroup52)
THANKS.
Don't know the exact pressure.. but anything between 30 and 35 psi should be fine...
Old Nov 7, 2003 | 04:30 PM
jerryp58's Avatar
jerryp58
Check your driver's door tag.
I know on my '77 it's low 20s. I don't run them that low; probably about 26 - 28 psi all the way around.
Old Nov 7, 2003 | 05:10 PM
Master Ho's Avatar
Master Ho
If they truly are the original tires, don't worry about the pressures. Instead, worry about them failing if you try to drive on 21+ year old rubber.
BTW, you might want to turn off the CAPS LOCK key... :)
Old Nov 7, 2003 | 07:03 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: TIRE PRESSURE? (Master Ho)
Not sure! Usually, 30 psi cold will be fine!
To TIRE PRESSURE?
