HELP!! Z Bar Removal
Old Nov 7, 2003 | 09:22 PM
gb9743's Avatar
gb9743
Default HELP!! Z Bar Removal
O.K. I give. How do you remove the bar that connects to the clutch pedal? It goes from the frame to the engine. There is a nut on the frame side and what appears to be a bolt that screws into the engine block on the engine side. I believe it is called the Z Bar. :banghead:
Old Nov 7, 2003 | 09:34 PM
PRESSURERAT's Avatar
PRESSURERAT
Default Re: HELP!! Z Bar Removal (gb9743)
Just take off the rods with the little spring clips, loosen the nut by the frame that you mentioned, and pull it up and out, nut side first.
Old Nov 7, 2003 | 09:37 PM
gb9743's Avatar
gb9743
Default Re: HELP!! Z Bar Removal (PRESSURERAT)
Thank you! :cheers:
To HELP!! Z Bar Removal
