Power Windows Not Working
Old Nov 8, 2003 | 10:02 AM
75SHARK's Avatar
75SHARK
Default Power Windows Not Working
Hello,
I have a '75 convertible and and both power windows quit working. I cheked first checked the fuse and there appears to be some sort of circuit breaker in place of where a fuse should be. I replaced the breaker with a fuse of the same amperage with no luck. I'm just wondering where I should go from here. Thank you in advance for any advice.
Robby Tessier, Baton Rouge, LA
Old Nov 8, 2003 | 10:31 AM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Default Re: Power Windows Not Working (75SHARK)
If you have voltage on both sides of the breaker (or fuse) check the relay (it's located in the console on my 71). Make sure you have key-on voltage to it. The key-on trigger is a large pink wire coming from a fused accy port in the fuse panel.
Dave
