Air Filter Height
Old Nov 11, 2003 | 04:21 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Air Filter Height
I have lots of clearance with the L88 Hood. So, I placed a 1 1/2 inch object on top of my existing 3 1/2 inch air filter and then looked through the windshield with a flashlight. There still appears to be at least an inch of clearance above the object.
So, would you increase the height of the filter to 5 or even 6 inches?
Old Nov 11, 2003 | 07:11 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Default Re: Air Filter Height (OHSIXX)
I don't think you'd see any performance benefit with your engine but if you like the looks, go for it. Keep in mind that the taller filters are more expensive and there's less selection to choose from. IMO, the money would be better spent if put towards something that actually improves performance like a taller intake manifold or a bigger cam.
Old Nov 11, 2003 | 08:08 PM
KenSny's Avatar
KenSny
Default Re: Air Filter Height (Vetterodder)
How about a Victor Jr.? Changes the power band somewhat but is still streetable.
Old Nov 11, 2003 | 08:57 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
With a solid lid filter the taller filter would yield a smoother flow path for the in coming air, which would result in less turbulence, which can result in better carb metering.
To Air Filter Height
