engine on a 1981
Old Nov 11, 2003 | 04:30 PM
guitar308's Avatar
guitar308
Default engine on a 1981
hi, i recently purchased a 1981 corvette and found out it has a 1999 motor placed in it. the motor cost $1100. i am wondering if ne one knows how many HP this engine would have, just a ballpark figure. thank you.
Old Nov 11, 2003 | 05:02 PM
Corvette_fetish's Avatar
Corvette_fetish
Default Re: engine on a 1981 (guitar308)
Can you elaborate a bit more? Is it an engine out of a '99 Vette? a '99 engine out of something else? a crate engine purchased in '99? What size is it? 305, 350, 383, 454, 502? You're question will be hard to answer considering the limited info you provided. $1100 does not seem to be a lot for an engine, but I'm not entirely sure. At this point you're looking at possibly anything from 190 to 350hp. Tell us more ... Or, take it to a local Corvette mechanic or used Corvette dealer and have them take a look at it to tell you what it is. :confused:
Old Nov 11, 2003 | 05:06 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: engine on a 1981 (Corvette_fetish)
probably a GM goodwrench TargetMaster/LM-1 , they have hecho en mexico cast on them (made in mexico), they make about 225-250 Hp depending on intake & exhaust.
Old Nov 11, 2003 | 05:14 PM
Corvette_fetish
Default Re: engine on a 1981 (Twin_Turbo)
Yea, I forgot about those. My '74 Camaro came from the factory with an LM-1.
Old Nov 12, 2003 | 01:26 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
yeah, sounds like the base crate motor. that seems to be around the right price for that. pretty good engine for the money. made as much power as the original L81 ever did, plus the cams probably don't wipe out in 50k miles like the originals.
Old Nov 17, 2003 | 12:11 PM
guitar308's Avatar
guitar308
it is a crate motor purchased in 1999 and is a 350 engine
Old Nov 17, 2003 | 12:44 PM
Corvette_fetish
I think Twin_Turbo hit it on the head. Look above.
Old Apr 4, 2012 | 10:35 PM
jim-81's Avatar
jim-81
that's what mine is. Mine was replaced by the PO about 5 years ago. It's a GM crate motor, not sure about the Targetmaster, but it could be. When I called the PO to ask him about it, he said it was 330 HP ... not sure about that, but it is definately more than 200.
Old Apr 4, 2012 | 11:32 PM
7T1vette's Avatar
7T1vette
I once knew a fellow that decided on his auto purchases based on a calculated "dollars per pound" basis. But, I didn't know that there was a similar proportional scaling for the "dollars per horsepower" ratio. Anyway, you can't make a good estimate of HP based on what the engine cost. Heck, it could be an LT1 engine out of a Corvette that the PO got from his dearest cousin Earl who works at a salvage yard. Or it could be a POS throw-away engine that the PO paid way too much for. Who knows?
But, if you tell us what rear end ratio the car has, what transmission, how much time it takes for you to run a standing start 1/4 mile, and some estimate of your prowess at running the car through its gears (100% is John Force; 10% is John Q. Public)....we might be able to estimate the horsepower (torque) being produced by that engine.
Or, maybe not....
To engine on a 1981
