Exhuast pipe is practically welded!
Old Nov 14, 2003 | 06:16 PM
homedawg247's Avatar
homedawg247
Default HELP!! Exhuast pipe is practically welded!
i am doing the exhaust on my 78 and i'm trying to get the mufflers off the rear y-pipe, right at the back axle. they are the stock pipes and probably havent been touched since 78. how can i get the mufflers off those pipes? i have removed the clamps but the muffler pipes are stuck in those other pipes
thanks
-johno
[Modified by homedawg247, 5:17 PM 11/14/2003]
[Modified by homedawg247, 5:32 PM 11/14/2003]
Old Nov 14, 2003 | 06:31 PM
homedawg247
Default Re: Exhuast pipe is practically welded! (homedawg247)
TTT
Old Nov 14, 2003 | 06:43 PM
GTR1999's Avatar
GTR1999
Did you try to cut s slice in the pipes from the side to open them up with a chisle? Eastwoods sells a tool to just this. 2 clamps that clamp on each side of the pipe. Theres a jack screw to separate them. I first saw these at Carlisle 2 years ago for $35.
Gary
Old Nov 14, 2003 | 06:56 PM
homedawg247
Default Re: Exhuast pipe is practically welded! (gtr1999)
the pipe coming off the muffler already hade a slit cut in it, i got up under it w/ a flathead and pryed it up and smothered underneath it w/ WD-40 but still no luck breaking it free. i heard that brake fluid will eat rust pretty well. might try some of that.
[Modified by homedawg247, 6:41 PM 11/14/2003]
Old Nov 14, 2003 | 11:02 PM
homedawg247
to the top
Old Nov 14, 2003 | 11:47 PM
79VetteMike's Avatar
79VetteMike
Default Re: HELP!! Exhuast pipe is practically welded! (homedawg247)
If you are close to an Autozone, they have a tool that you can borrow(loaner tool program) that cuts the pipe. It is a handle with a chain that wraps around the pipe. The chain has sharp round blades to cut through the pipes just like a plumbing pipe cutter.
Old Nov 15, 2003 | 10:36 AM
bigvette1's Avatar
bigvette1
If the pipe and muffler have been on a long time they are usually mated. The rust, carbon, and the clamp tracks make it damn near impossible to get apart in 1 piece. You might have to cut the exh. pipe back, cut off the damaged piece and then use a sleeve joint of the OD/ID size to put them back together. The auto store have all the sizes.
Old Nov 15, 2003 | 11:01 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Exhuast pipe is practically welded! (bigvette1)
If you have a cutting torch or a friend that has one you can cut the outer pipe off without cutting the inner pipe. really!
It's a 30 second job with the torch...
To Exhuast pipe is practically welded!
