Shifter Help needed
Old Nov 15, 2003 | 04:32 AM
72CoupeORG(smc)'s Avatar
72CoupeORG(smc)
Default Shifter Help needed
doing some R&R on my 72 the other day & i had purchase a shifter rebuild kit for my 4 speed. i disassebled the console, boot, linkage, etc but could not figure out where the shifter was bolted on. so needless to say, I cleaned & lubed what i could see of it & put it back together.
So the question is..........How do you remove the shifter?/
boy, do i feel stoooopid!
[Modified by 72CoupeORG(smc), 4:33 AM 11/15/2003]
Old Nov 15, 2003 | 08:07 PM
Duke94's Avatar
Duke94
Default Re: Shifter Help needed (72CoupeORG(smc))
The shifter is bolted to a bracket that is bolted to the trans crossmember. You get to it from under the car. It's on the drivers side. 2 bolts hold it on.
Old Nov 15, 2003 | 10:24 PM
trw's Avatar
trw
:iagree: Tight space, but doable. And its worth the trouble, really makes smoother shifting.
Have fun.
Terry
Old Nov 16, 2003 | 04:36 AM
72CoupeORG(smc)
Default Re: Shifter Help needed (trw)
thanks--now the fun begins!
Old Nov 16, 2003 | 11:11 AM
Easy Rider's Avatar
Easy Rider
Did you buy the shifter rebuild kit from Zip that has the shijm plates to restore your shifter to its original, new feel? I bought one too, but have not yet put it in.
How did the installation go and are you satisfied? Did you have to take it out and insert the other shim plate or did you get it right the first time?
Jim
To Shifter Help needed
