Engine Mounts and Front End Strength
Old Nov 15, 2003 | 08:36 PM
1979toy's Avatar
1979toy
Default Engine Mounts and Front End Strength
Will solid motor mounts contrubite any real strength to the front of the frame?
Will the added strength be noticable enough to offset the expected engine vibrations?
Old Nov 16, 2003 | 01:35 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Default Re: Engine Mounts and Front End Strength (1979toy)
I plan to install solid mounts for reliability ie. never have to worry about them breaking. I would think that it would strengthen the frame the same way the spreader bar between the front shock mounts does.
I have no idea what the increase in vibration is. The rubber mounts are pretty hard to begin with.
Old Nov 16, 2003 | 02:39 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Re: Engine Mounts and Front End Strength (turtlevette)
Compared to a spreader, the engine mounts are much lower to the frame, so I don't think they'll have nearly as strong of an effect. Especially since there already are mounts there, just not AS hard as the solids. But, on the other hand, every little bit counts!
Old Nov 16, 2003 | 03:02 PM
Corey_68's Avatar
Corey_68
Default Re: Engine Mounts and Front End Strength (RUXperienced)
I went with Poly Mounts, I have them BOTH Strength and Less Vibrations.
:cheers:
To Engine Mounts and Front End Strength
