Won't idle??
Old Nov 15, 2003 | 10:07 PM
Dk Met Grn 80 L82's Avatar
Dk Met Grn 80 L82
Default Won't idle??
After driving fine, she began to stall everytime I came to a stop. Got her home. She will not even idle. Pulled carb and complete rebuild. No change. Puking unburnt fuel out both tail pipes about two feet long on the ground. Pulled all spark plugs, carbon deposits but generally ok. Vacuume is low 5-10 at 1500rpm. Have to keep my foot on it to keep her running. Found EGR valve bad, capped vacuum line to it for now. Could a bad EGR valve be causing all this trouble? Advise? :smash:
Old Nov 15, 2003 | 10:24 PM
killervette666's Avatar
killervette666
Default Re: Won't idle?? (Dk Met Grn 80 L82)
sounds like your running WAY to rich, i have the same thing right now with unburnt fuel, but our idle is to high, anyways sounds like your running rich. Check your choke, that could cause the stalling. :chevy
Old Nov 15, 2003 | 10:58 PM
80Xflags's Avatar
80Xflags
Same thing here . . . except I'm not puking fuel out of the tail pipes, I'm puking fuel out of the primary discharge nozzles and flooding the intake. :mad
Matt
Old Nov 15, 2003 | 11:55 PM
Dk Met Grn 80 L82
Default Re: Won't idle?? (killervette666)
It's an electric choke. Closes when starting, opens slightly, then continues to open until straight up when warmed up. This part seems to be working ok.
To Won't idle??
