GM Fastener Specification Database?
Old Nov 16, 2003 | 11:50 AM
VetteNut72's Avatar
VetteNut72
Default GM Fastener Specification Database?
Is there any information available that cross-references the GM part numbers for nuts, bolts and washers listed in the AIM with the actual specifications(Length, diameter, threads per inch, grade, ...)?
Craig
Old Nov 17, 2003 | 09:07 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Default Re: GM Fastener Specification Database?
Craig,
Yes, there is a GM source called the Standard Parts Catalog. It lists the exactly the information that you listed, plus some additional information on certain fasteners such as finish.
The problem is that these manuals are very hard to come by (and very expensive if you do)... Add to that they are not all inclusive so you'll need about ten years worth of manuals prior to the model year of your car to make sure that all of the fasteners that you are interested in are covered.
Good luck in your search!
Regards,
Old Nov 17, 2003 | 09:21 AM
Tom454's Avatar
Tom454
Default Re: GM Fastener Specification Database? (Rowdy Rat)
:iagree:
I have a few copies and they are not "all inclusive".
If you take a fastener number out of an assembly manual, it may not be listed in the Standard Parts Catalog. As time passed, GM replaced the old numbers with new ones... they have a computerized list of superceded numbers, which in itself has gaping holes.
Fasteners are a tough nut to crack if you're tryting to keep the car mildly original, or even if you just want to replace "bubba" fasteners with the correct type.
During a production run, any fastener was a target for substitution as well.
I have spent countless hours trying to track down the correct fasteners for various years.
My frequent visits to the Chevy Dealer is what prompted them to give me my own set of GM books. The "catch" was that anything I looked up myself and ordered was not returnable for any reason. I have "boxes of 100" of many GM fasteners that I only needed a few of.
Old Nov 17, 2003 | 02:34 PM
Todbo's Avatar
Todbo
Default Re: GM Fastener Specification Database? (Tom454)
I 've had some luck using companies such as Paragon who list a lot of bolt and fastner specs in their catalog , but I spend most of my time doing the "ole' trial and error" :smash:
To GM Fastener Specification Database?
