speedometer/speedo cable issue
Old Nov 16, 2003 | 12:35 PM
munday's Avatar
munday
Default speedometer/speedo cable issue
well i got the car to stop dying in gear ...vacuum leak...
but my speedometer still doesn't work. It's a new cable and a new speedo. The speedo works and the cable is fine, what else could it be? with the cable plugged into the tranny i can spin it....is there something in the tranny that's broken? :rofl:
Old Nov 16, 2003 | 01:42 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Default Re: speedometer/speedo cable issue (munday)
The square hole in the plastic gear in the tranny might be rounded out.
That happens when the cable kinks.
Old Nov 16, 2003 | 01:48 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: speedometer/speedo cable issue (turtlevette)
Pull the cable back out of the tranny. Reach up and pull the gear out of the tranny and inspect that gear. If it appears to be ok, put your finger into the hole and feel for the gear that is supposed to be on the output shaft. Mine came off its mooring and I had to take the tailshaft housing off to put it back into place. Hope this helps.
To speedometer/speedo cable issue
