Bumpsteer .... The topic that won't die
Seriously, though, fascinating subject. Thanks to all.
I dunno why the general did that, except someone was in a hurry in the initial design way back in 63 or so for the 65 model, and so they created two part numbers, and that is the differance....
don't ask me how I know, I scratched my azz for about two hours trying to find out why those rotors would not fit the pads on my car....
talk about sneakey, that's it.....
GENE
I noticed the same thing after gene told me this some time ago, I hadn't noticed it before, so I went and measured and lo and behold they''re different
Once the rotors are installed I check the clearance front and back of the caliper to make sure the rotor is in the middle and not pushing to one side.
I found both my fronts needed the caliper moved towards the centerline about 1/16-1/8th of an inch.
those spindles look pretty nice. I can't wait to hear what they do to the roll center and the camber curve.
one of the things I plan on doing, maybe this weekend, is to baseline the Camber curve, so when you put in your new spindles we can see how much of a change they made.
Gene,
thats scary! I wonder how many Vettes have them mixed up?
I don't mind broad learning curves, but it's better spend on learning the curves of a broad if you get my drift......
but on a highly wrung out modified car like Norvals with that machine work in the rear spindle area that he did, all bets on anything are off.....hell, he got a custom everything there, damn near....
GENE
One thing that I don't think anyone but redvetracr and myself have done is plate over the hole on the frame on the outside of the steering box. This area is extremely weak/flexable. Just have a steering control valve not balance and the wheel going back and forth and this area flexes like it is make of paper,'
I plated over the outside and underside to strengthen this area. Makes for quicker response to steering input.
Look at this site guys and look under chassie for tips on helping our frames http://www.corvettefaq.com/susp.asp
I intend to remove my entire front suspension, add a spreader bar. reweld the area around the towers and lower mounting points of the trailing arms, box the frame where the sway bar bolts, beef up the lower mount for the sway bar on the A arm and gusset everything. Alot of paint to remove, cracks to clean out then mig weld everything.
This is a pic of mustang II suspension, but the idea is the same...
Let's call the ball joint side of the lower a-arm point 1, and the right side point 2 :skep:
Now let's place a tie rod directly in front or behind the lower a-arm with one end of the rod in line with point 1 and the other in line with point 2.
(The tricky part) Modify the spindle so that it has a steering arm that reaches down and connects with the tie rod in line with point 1.
At point 2 move the steeroids mounting plate (the one on the hydrolic pump) until it can connect with the tie rod.
Because the tie rod is on the same plane as the lower a-arm and pivots at the same points, there should be no bumpsteer when the car is pointed straight forward. It moves exactly like the a-arm.
There's more, but I want to see if I am making any sense so far.
Comments?
[Modified by applevette, 10:53 PM 11/19/2003]
And I'm talking about within .050" or so I think!
I'll know more precisely when I do more testing...
The parrallel assumption is a rule of thumb used because most tie rods are either very close or just above the lower arm, most modern (..ooops corvette falls out of this category LOL) have lower arms that are almost vertical so the tie rods are too.
Doing it with the IC will ensire the proper arch on the tie rod. However, it takes VERY carefull measurement and you can''t transfer it from one car to another. Measure everything as good as you can, a little error can already upset the design.
Twin Turbo it is too late to really put thought into your idea but tomorrow I will certainly try to understand what you are saying.
For a kid of only 28 you seem to really know you stuff. :lol: :lol: :lol:
That's a joke Twin turbo.
Have a nice evening.
"The tie rod MUST point to the instantanous center and be of the correct length for zero pump steer..." "...the lower A arm always points to the instantanous center."
So does this mean that my idea, provided the length of the tie rod is correct, will work also? Or am I just being dense?
you work there??? they used to do a lot with pulleys and engines, and TPI a few years ago....been a while since I got a catalogue....
Yeh, the front ends and also the IRS are open topics to us more advanced hotrodders here, all sorts of good information from a bunch of smart guys....
Pete79L82 is one, Norval is another, 427 is a good source too....just to name a few....
IMO, the original steering was fine in it's day, well before even radial tires were common, but with modern tires, well some of the inadequacies show up, just one of them is the tendency even with new steering/suspension work/parts to follow the truck ditches in the roads at speed....huge problem here in Florida with all this sand underneath....I was constantly fighting the issue, and cured it with a rack....I think it's due to the valve in the hydraulic assist of the old original design, that and the olde tyme suspensions....
GENE
:thumbs:
Norval said
Being rear steer in it's self has a lot to do with the squirrlyness due to what happens when bushings deflect on a rearsteer car vs a front steer car...
But I think Bumpsteer is a pretty good bang for the buck!
SSS Said
[Modified by 427V8, 8:02 AM 11/20/2003]
