Engine Identification
Old Nov 16, 2003 | 10:20 PM
USA SHARK's Avatar
USA SHARK
Default Engine Identification
I recently bought a 1977 L-82 manual, however it definitely no longer has the L-82 engine. The engine casting number is 3914678 which is identified by Mortec as one of the following:
3914678....302.....68....2...Z-28 Camaro
3914678....327.....68....2
3914678....350.....68....2
The VIN number on the front of the engine block is V0507HH. Does anyone know which engine might be in the car or what else I can check to determine if it is a 302, 327 or 350? About the only thing that is certain is that it is from 1968.
Thanks for the help!
Old Nov 17, 2003 | 12:34 AM
Tom73's Avatar
Tom73
Default Re: Engine Identification (USA SHARK)
The "HH" suffix was used three times. First in 1965 327ci/365hp in the Vette, then in 1966 as a 327ci/300hp in the Vette, and finaly in 1969 as a 350ci/300hp in the full size chevy.
What is the casting date (on the other side from the casting #)?
tom...
Old Nov 17, 2003 | 08:12 AM
USA SHARK's Avatar
USA SHARK
Default Re: Engine Identification (Tom73)
Thanks Tom....
Just to the left of the casting number it has a large GM and the number 8. I don't see any other numbers.
I want to order a few things, but I'm just not sure what engine I have. I wish I knew a little more about engines :(
[Modified by USA SHARK, 7:12 AM 11/17/2003]
Old Nov 17, 2003 | 08:18 AM
Tom73's Avatar
Tom73
The casting date would be on the passanger side of the block at the rear near the bellhousing flange (like the casting # but on the other side). Will look something like B129 for Feb 12, 1959/69/79 or the like.
tom...
Old Nov 17, 2003 | 09:06 AM
USA SHARK's Avatar
USA SHARK
Thanks again Tom...
I found it. It is either E 68 or E08, but I believe it is E68 (I am sure of the E and the 8).
Old Nov 17, 2003 | 09:15 AM
GaryS's Avatar
GaryS
Be very careful when you read these. I have mistaken 9's and 8's many times because of the font used.
Gary
Old Nov 17, 2003 | 09:53 AM
USA SHARK's Avatar
USA SHARK
Default Re: Engine Identification (GaryS)
Here is a pic of the date. You can't see the E, but I know that is right. I'm pretty sure it says E 68
Old Nov 17, 2003 | 09:58 AM
Tom73's Avatar
Tom73
My guess would be that it is the 350ci/300hp from a full size chevy
tom...
To Engine Identification
