Gas Tank All Done
Old Nov 17, 2003 | 12:03 PM
VetteNut72's Avatar
VetteNut72
Default Gas Tank All Done
Here is the tank after being redone. I don't have a before but it was really bad. The outside was cleaned with Marine Clean, prepped with Metal Ready, coated with POR-15 rust preventative and painted with tie coat primer. The final finish is two coats of VHT Aluminum Epoxy paint. The inside was also cleaned with Marine Clean, prepped with Metal ready and coated with Gas Tank Sealer.
Here are some pictures of the coating on the inside of the tank.
Craig
[Modified by VetteNut72, 10:05 AM 11/17/2003]
Old Nov 17, 2003 | 12:09 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Re: Gas Tank All Done (VetteNut72)
What a fine addition to your kitchen :D
Turned out great :cheers:
