Poly or Rubber
Old Nov 20, 2003 | 10:27 AM
johnnyc's Avatar
johnnyc
Default Poly or Rubber
About to order the front suspension kit from Vansteel. I need input from you guys, should I go with poly or rubber control arm bushings. The car is a bone stock '79, driven about 3000 miles per year. No hard driving, just pleasure cruising. Please let me know the good and bad points of each.....Thanks.
Old Nov 20, 2003 | 10:42 AM
GDaina's Avatar
GDaina
Default Re: Poly or Rubber (johnnyc)
Rubber for the type of driving you describe, Poly for spirited, competive driving
Old Nov 20, 2003 | 11:48 AM
78 Vette's Avatar
78 Vette
Default Re: Poly or Rubber (GDaina)
I have the poly bushings they work great but I dont care what you do to them they are gonna make noise. That grease they give you lasts about a month. :mad.
[Modified by 78 Vette, 11:49 AM 11/20/2003]
Old Nov 20, 2003 | 12:06 PM
markdtn's Avatar
markdtn
Default Re: Poly or Rubber (78 Vette)
I saw Poly, they should last a lot longer. There may be some noise, but it doesn't bother me-it's a Corvette not a Rolls-Royce. Honestly I don't have much noise at all.
Old Nov 20, 2003 | 12:07 PM
johnnyc's Avatar
johnnyc
Great, This is the info I am looking for....JC
Old Nov 20, 2003 | 12:47 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
:iagree:
Old Nov 20, 2003 | 02:22 PM
Augie 79's Avatar
Augie 79
Default Re: Poly or Rubber (Sigforty)
If you go poly you'll never have to do this job again on this car. That's what made my mind up.
Old Nov 20, 2003 | 02:49 PM
johnnyc's Avatar
johnnyc
My real concern is squeaking. I installed a rear sway bar w/poly mounts, and it squeaked like hell. I ended up replacing the poly mounts with rubber. I'd like to avoid doing my c-arms twice.....JC
Old Nov 21, 2003 | 07:18 AM
isosceles's Avatar
isosceles
I had Van Steel install the poly kit on my car March 03. Even with all the soggy weather here in FL I have NO sqeaks. :D
Old Nov 21, 2003 | 11:59 AM
TedH's Avatar
TedH
I agree. Rubber for a daily driver.
Old Nov 23, 2003 | 11:33 AM
loose nut's Avatar
loose nut
I prefer poly on suspension components and rubber only on body mounts.
Old Nov 25, 2003 | 06:32 PM
Tpls 69's Avatar
0Tpls 69
Former Vendor
I agree. I have the poly in the back and they chirp like little birds. A friend made up my mind when I replaced the front bushings. Quote" Those rubber bushings have lasted on the car for 34 years. You won't be around when the new ones go" Can't argue that logic. :steering:
Old Nov 26, 2003 | 12:31 PM
johnnyc's Avatar
johnnyc
Default Re: Poly or Rubber (Tpls 69)
Lets see...In 34 years, I'll be 75. I'm going with the rubber. TPLS 69 I like your logic, I'll let my son worry about it in 2037. Thanks guys for the input.
Regards,
John
Old Nov 26, 2003 | 12:47 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I put poly into my front end 2 years ago and they make no noise. I chose them because you can install them your self and don't need a press to install them. That and if and when they do wear out (not likely to happen) I can just pop them out and pop new ones in.
Old Nov 26, 2003 | 12:53 PM
desi's Avatar
desi
Looks like the forum is divided on this one....
I was thinking of going with poly on suspension, and rubber on engine and tranny mount.
I think you should start a poll...
Old Nov 26, 2003 | 01:02 PM
Edzred72's Avatar
Edzred72
I have poly on the 77 with no squeeks after 1 1/2 yrs. Greased em up with synthetic before install. I've seen grafite inpregnated poly bushings lately. They should NEVER squeek.
Eddie
Old Nov 26, 2003 | 03:25 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: Poly or Rubber (Silvr77)
I have Poly everything exept Bodumounts,but soon they`ll be Poly too :smash: :cheers:
To Poly or Rubber
