Replaced back up switch on side of trans with new switch.
New switch came with wires and connector.
I can not see any thing to connect this to under car.
Old switch had no wires connected to it.
All tail lights work but back up have not.
Where do I begin to look to connect this to??????? :confused: :banghead:
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Re: Back up lamp help (John D.)
There should be a tail on the switch with an L shaped connector on it. It should plug into a connector that has the same plug (female/Male) with green colored wires on it. This was located about midway down on the drivers side of my bellhousing. Yours should be in this general vicinity. Hope this helps a little. Good luck.
I do have the tail L connector comming off new switch. Will look for matching end around bell housing. Thank for the advice. Sure hope it is there.
Love to get reverse light operating.
Thanks, John. :seeya :chevy
