C3, L.E.D.'s ANyone converted yet?
Old Nov 21, 2003 | 09:56 AM
Madmikeee's Avatar
Madmikeee
From: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
Default C3, L.E.D.'s ANyone converted yet?
Just wondering if anyone has converted from the standard bulbs to the L.E.D.'s available out there?
I have been considering doing it as the bulbs in my 77 are a little on the Dim side. :cheers:
Old Nov 21, 2003 | 10:56 AM
79 Midnight Blue L82's Avatar
Default Re: C3, L.E.D.'s ANyone converted yet? (Madmikeee)
I replaced my tail light bulbs with the led's about a year ago and they are OK. Have a little different look to them and maybe just a little brighter.
Old Nov 21, 2003 | 11:28 AM
pws69's Avatar
pws69
I put the 'Stylin Concepts' 1157 direct replacement LED's in my 69 rear lights about a year ago and I really like them Very bright and fast.
One comment, though, if your standard bulbs are dim, then you may have connection issues (either ground or 12v).
[Modified by pws69, 11:29 AM 11/21/2003]
Old Nov 21, 2003 | 01:06 PM
Madmikeee's Avatar
Madmikeee
Cruise-In X Veteran
St. Jude Donor '06
Default Re: C3, L.E.D.'s ANyone converted yet? (pws69)
Ya I figured that as well and I will be going through the system when I get a chance to make sure all is well.
Old Nov 22, 2003 | 01:26 AM
Spook's Avatar
Spook
You use thier load equalizer and whatnot? What did it cost you overall?
Old Nov 22, 2003 | 02:48 AM
Pete76Shark's Avatar
Pete76Shark
Check out this option:
http://forums.corvetteforum.com/zerothread?id=680443
Old Nov 22, 2003 | 08:17 AM
garandfan's Avatar
garandfan
CI 5-6-7-8-9 Veteran
Cruise-In 7 Car Show Winner
Default Re: C3, L.E.D.'s ANyone converted yet? (Pete76Shark)
I'm in the middle of a complete rebuild. Part of it is to eliminate the back up lights and go with a four way brake/tail light system.
I found a super neat set of clear white chrome LED lights that will fit in with a chrome bezel cover for the rubber fittings.
The fiberglass was cut to allow the mod, and I have all four slots trimed and test fitted.
The lights are white lens, with chrome insides, and shine red when lit.
The mods are on a 70 with shallow lights, and the mod I did will not effect the use of the standard lenses, or the housings.
You shouldn't have to do this mod unless you have a chrome bumper vette, the later c3's with rubber bumpers have deaper slots for the lights.
Total cost for lights, bezels,rubber fittings, and connectors: $179.00
I'll post picures when I can.
Frank
To C3, L.E.D.'s ANyone converted yet?
