Adhesive for installing carpet?
Old Nov 22, 2003 | 10:58 AM
68goat's Avatar
68goat
Default Adhesive for installing carpet?
We are installing new carpet today in the '79. What type of adhesive should we buy? would the 3M kind work or do we need something stronger? Also, if you have any pointers you want to tell, im all ears :)
Old Nov 22, 2003 | 11:07 AM
Garson's Avatar
Garson
Default Re: Adhesive for installing carpet? (68goat)
The 3-M adhesive will work fine, just follow the instructions. A good heat gun comes in handy to form a few of the corners. Make sure the carpet is not cold when installing. It will fit and form a lot better when warm. Make sure of the fit before you cut and trim.. Are you installing a heat/ sound barrier?
Garson
Old Nov 22, 2003 | 11:09 AM
68goat's Avatar
68goat
Default Re: Adhesive for installing carpet? (Garson)
No, im not installing new heat/sound barrier, beleive it or not, but the old stuff is still in great shape, so ill be re-using it.
Thanks for your help!
Old Nov 22, 2003 | 01:40 PM
KenSny's Avatar
KenSny
Used 3m spray to install my insulation pad and carpets through-out the car. I think Permatex also makes a similar product.
To Adhesive for installing carpet?
