Wiper Delay Electronics
Old Nov 22, 2003 | 01:59 PM
Zane's Avatar
Zane
Default Wiper Delay Electronics
Is this my Wiper Delay Electronics??
If so where can I buy a new one. This is the last item to be replaced.
Old Nov 22, 2003 | 07:54 PM
Zane's Avatar
Zane
Default Re: Wiper Delay Electronics (Zane)
Does Anyone know where to get one of these?
Old Nov 22, 2003 | 08:08 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Zane, take it to a Chevy dealer, it's bound to have a part number on it, if it does there is a good chance they might have it in stock. These units were used on a number of different vehicles over a span of several years.
If you can't locate a replacement from the dealer try one of the Corvette used parts dealers. Gary Gruhala is a good place to start, he can be located at http://www.angelfire.com/mo2/GruhalaEnterprises Give him a call, he's a great guy to deal with.
Good Luck!
Old Nov 22, 2003 | 09:59 PM
mrvette's Avatar
mrvette
Default Re: Wiper Delay Electronics (Smokehouse69)
What Smoke says, but also you may want to take it apart and see if there are any loose connections on the circuit board, and solder them up again....
I understand it's a problem with the circuit boards, just like in modern cars...
GENE
Old Nov 22, 2003 | 11:09 PM
Zane's Avatar
Zane
Default Re: Wiper Delay Electronics (mrvette)
I already took it apart. There are no loose solder joints. If I cannot find a replacement I'll probly see if I can replace the tri-acks and capacitors to see if that will make it work again.
Old Nov 23, 2003 | 12:53 AM
Fleetwood's Avatar
Fleetwood
Before you start replacing parts,test the relay first.Unplug it,using a meter on ohms,find the internal coil,put 12V across the coil.You should hear the relay pull in.With the meter across the contacts,you will see the contacts change from normally closed to normally open or vice versa.
Old Nov 23, 2003 | 10:12 AM
mark79,80's Avatar
mark79,80
If this is for an 80, then the part no. is 14016250. I did purchase several in
September 2000 and the list was $259. The dealer I bought them takes
25% off list. I searched for them today on several GM dealer's web sites like
GM parts direct and the number did not come up. You may want to call
your local dealer, give them that number and it may have been changed.
Zip products also listed ES-388 at $259 in their 2002 catalog.
Also looked at Parts Voice web site which is great for finding dealers who have NOS parts. It showed Pacific Corvette as having one.
They are at 800-228-2857.
[Modified by mark79,80, 9:13 AM 11/23/2003]
Old Nov 23, 2003 | 11:37 AM
Zane's Avatar
Zane
Default Re: Wiper Delay Electronics (mark79,80)
Relay has been checked long before I posted. Thanks for the idea.
This is a 78 and I just tried that part number at GMDirect and nothing. I'll check on Zip as I had no idea they had one.
Old Nov 23, 2003 | 12:08 PM
Stephen Irons's Avatar
Stephen Irons
2024 C3 of the Year Finalist - Unmodified
Zane
Where did this come from on teh car? I ask, as I seem to recall that the wiper delay relay on mine didn't look quite like this? Mine is under the centre console (on a 78) and from memory (alas, the car is in it's garage, 2 miles from home) mine seemed a littel more complex?
Regards
Old Nov 23, 2003 | 07:49 PM
Zane's Avatar
Zane
Default Re: Wiper Delay Electronics (Stephen Irons)
Mine is in the same place in the console
Old Nov 23, 2003 | 10:18 PM
mark79,80's Avatar
mark79,80
Part numbers I gave you are for 1980-82, the delay module is located
in the jack compartment. The 1978 you are looking for takes a
different module. Not sure how different it is from the 80 thru 82.
The 1978 and 79's used GM part no. 14005004 which is most likely
discontinued. Using that no. you maybe able to find an NOS one
somewhere.
Pacific Corvette is listed as having one. This is the source I used to
search for the part. It is very handy for locating current and discontinued
parts: http://www.partsvoice.com/
[Modified by mark79,80, 9:22 PM 11/23/2003]
[Modified by mark79,80, 9:27 PM 11/23/2003]
To Wiper Delay Electronics
