Should I get new bearings?
Old Nov 22, 2003 | 07:14 PM
79VetteMike's Avatar
79VetteMike
Default Should I get new bearings?
I'm blueprinting my front bearings. One side is .003". The other side is .004". I am checking the hub assembly itself. I know that this is within tolerance, but I'm a perfectionist. I'm happy with the .003", but I'd like to get better than the .004". Is it possible that the bearings aren't perfect? I've taken the assembly apart and made sure that the race is seated all the way down. It has to be either the bearings or the hub itself. Any other suggestions?
Old Nov 22, 2003 | 08:47 PM
GDaina's Avatar
GDaina
Default Re: Should I get new bearings? (79VetteMike)
I think you like to split hairs
Old Nov 22, 2003 | 08:51 PM
79VetteMike
Default Re: Should I get new bearings? (GDaina)
Ummm....how thick do you think those are? Are you thinking I could use it to shim?
Old Nov 23, 2003 | 01:31 AM
Spook's Avatar
Spook
Why not get the new bearings while your there... hehe... Maybe just repack? I dont know heres a TTT though.
WIAI (While I'm At It!) Member Since 2002 - Counciling available...
Oh if you use hairs to shim be sure to pull some from down low... they are tougher! :eek:
[Modified by Spook, 1:33 AM 11/23/2003]
Old Nov 23, 2003 | 08:39 AM
GDaina's Avatar
GDaina
Default Re: Should I get new bearings? (Spook)
:skep: :skep: :U :U :leaving: :leaving:
To Should I get new bearings?
