Vacuum evacuation system update...
Old Nov 23, 2003 | 09:14 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Vacuum evacuation system update...
For those who don't know - I had a vacuum evacuation system installed when I had my carbon fiber shafts installed.... Those kind of systems create a vacuum in the crankcase which helps the piston rings to seal better... because piston rings tend to flatter if too much pressure builds up.. If there's a vacuum - they'll seat better. So that's the theory.. but how were my results??
Well - that system really works... I reduced my oil consumption (which I believed was 95% from the intake gasket) from 1 quart for 200 miles to less than 25% of that... a 75% reduction.. The car also stopped smoking at idle.. :eek: :eek: :cool: :cool:
Old Nov 23, 2003 | 09:37 AM
comp's Avatar
comp
Default Re: Vacuum evacuation system update... (GrandSportC3)
you did fix intake leak?? if no vac.system not going to work as well, how much
vac. are you pulling on average?
Old Nov 23, 2003 | 09:50 AM
GrandSportC3
Default Re: Vacuum evacuation system update... (comp)
Well - it looks as if the intake leak was only part of my problem.. I think that what was happening was that I was sucking the oil into the engine through the PCV system... Now that I don't have a PCV system anymore - that can't happen.. Another thing is that the PCV system has most vacuum at idle and the Vacuum evacuation system's vacuum increases with RPM... That's why I had the smoke at idle.. The vacuum on the PCV hose would just drink oil from my crankcase whenever there was high vacuum (low RPM)...
The evacuation system makes more sense.. THe higher the RPM - the more pressure builds up in the crankcase.. The PCV has hardly any vacuum at high RPM's.. However - that's when the vacuum is needed most... The evacuation system also prevents leaks at all the gaskets because of eliminated pressure in the crankcase.. It was one of the best things that I've done to the car so far!! :yesnod: :yesnod:
Old Nov 23, 2003 | 10:02 AM
comp's Avatar
comp
bear with me new to typing, at idle you shouldn't be getting ring flutter, so
you need to do a hot/cold compression test then a hot/cold leak down , do you measure crankcase vac. i was told to do so, a malfuction can Vac. the
oil pan quik
Old Nov 23, 2003 | 10:25 AM
GrandSportC3
oil pan quik
No ring flutter at idle.. but high vacuum at the PCV which was sucking oil out of the crankcase into the engine.. I did a compression test on the engine and all the cylinders had about the same pressure!
PCV systems have high vacuum at idle and low vacuum at high rpm's.. That doesn't make sense.. The higher the RPM - the more vacuum you want to neutralize the pressure..
[Modified by GrandSportC3, 10:26 AM 11/23/2003]
Old Nov 23, 2003 | 10:40 AM
comp's Avatar
comp
i understand , high idle vac,(mild cam) you can tune induction buy measuring
vac. at top end, if you show more than 2-3ins go a little more for HP for MPH,
thing is pvc is lets say pulling 20ins of vac. and its sucking oil, (WHY) is it....
if you don't pull as much with vac. system you aren't going to be pulling as
much blow-by out
Old Nov 23, 2003 | 10:44 AM
GrandSportC3
much blow-by out
Well - I'm no expert.. It's all a theory.. The only thing that I know for sure is that my oil consumption is 75% lower with that system.. That's a fact.. I'm sure that the remaining 25% is at the intake... I'm changing intakes in about a week to see if I can completely eliminate oil consumption...
Old Nov 23, 2003 | 11:02 AM
comp's Avatar
comp
i ain't the expert ether, test crankcase vac. before/ after you do repair, at
different RPM's W.J. was winning in P/S w/o a vac system when other teams
couldn't control their oil systems, and started running them, and i do know a
dry sump system draws vac.
any way test it out, fix the intake and let me know , i love to learn...
Old Nov 23, 2003 | 11:08 AM
GrandSportC3
When I replaced the intake gasket - it was indicating that it leaked some oil... Oil consumption didn't improve after I changed the gasket.. The intake that I use is over 35 years old and the surface is a little rougher than on a brand new intake... I will get my Victor Jr. soon. I can't wait to see if that will help me to get rid of the rest of my oil consumption.. which is already much lower now... I don't have any equipment that measures vacuum.. so I can just guess... I only try to look at the facts... The vacuum evacuation system was the only change to the engine to go from 1 quart for 200 miles to less than 1/4 quart for 200 miles... which would mean that I'm down to around 1 quart/1000 miles which isn't too bad..
Old Nov 23, 2003 | 11:35 AM
comp's Avatar
comp
go to Autozone or Wallyworld get a cheap vac gauge to use,and tune with it
may be old school but it works, tap in to line you plumed to engine to take
readings , you can use it to tune with after the new intake(& rejet) i even
used a $6-7 one to test ex. back pressure at lest 8 times before it got to hot,
(yep driving around town) it was cheaper than throwing parts at cars
and remember NEW TOOLS headin' World of Wheels let me know how you
do..
Old Nov 23, 2003 | 11:52 AM
GrandSportC3
do..
I might get one of them gauges.. Thanks! :thumbs:
To Vacuum evacuation system update...
