73 Owners......
Those of you with 73's can you tell me what the proper key codes should be?
When I bought my 73 it cam with a code J ignition (square) and a code E for the doors (also square) what is the right door code? is there a round key (code D or H) that is the same as the square code E?
Re: 73 Owners...... (GREGG-73)
Thanks for the replies, I thought the doors should be a round key like other GM models. the 74 I have for parts came with a square code E for the ignition and a round code K for the doors, is this right :confused: :confused:
Steve :steering:
"74"-IGNITION KEY SHOULD BE A "J" LETTER STAMP (SQUARE) ,"K" (OVAL) FOR ALL OTHER. :cheers:
My ign must have been replaced since it has an 'A' code and I have a second square head which I believe is for the alarm and an oval for the doors. :confused:
