angle plug heads
Old Nov 24, 2003 | 03:41 AM
standup's Avatar
standup
Default angle plug heads
Are there any downsides in using angle plug heads with stock 350 Chev ramhorn exhaust manifolds?????
Thanks :cheers:
Old Nov 24, 2003 | 08:41 AM
Fevre's Avatar
Fevre
Default Re: angle plug heads (standup)
I ran Trick Flow angled plug heads with no problems. The angle actually moves the boot away from the manifolds. I used Summit 8mm 180 degree (straight) boot wires and only had a problem when I brook in a cam running it too lean making the rams horns glow. :eek:
[Modified by Fevre, 8:42 AM 11/24/2003]
Old Nov 26, 2003 | 03:37 AM
standup's Avatar
standup
Default Re: angle plug heads (Fevre)
Cheers, mate....... :cheers:
I promise I won't make the manifolds glow..... :)
To angle plug heads
