Q-Jet Question
Old Nov 25, 2003 | 01:29 PM
pra4sun's Avatar
pra4sun
Default Q-Jet Question
I am supposed to have carb # 7040213 on my car (Late '70, 350, 4 spd), but I have carb # 7042114 (1972, 350, auto) installed.
Should I have any concerns about the performance of this carb, compared to stock?
I have always had choke operation problems that I can fix, then something else will go wrong with it. Now, the fast idle cannot be set by pressing the gas pedal. I have to remove the air cleaner and do it manually.
Old Nov 25, 2003 | 02:14 PM
Shark Racer's Avatar
Shark Racer
Default Re: Q-Jet Question (pra4sun)
The only difference between the two carbs should be in the jetting/rods- the rest is in the condition of the carb.
You may want to consider getting it professionally rebuilt, or since the carb isn't matching numbers anyways, order a new one from recarbco or the like.
I just picked up a recarbco quadrajet for my 78 and they do a GREAT job. Be sure to give them the # of the original carb for the car, and who knows, maybe they'll even have a matching # core in their supply.
recarbco.com
-Steve
Old Nov 26, 2003 | 12:32 PM
pra4sun's Avatar
pra4sun
Default Re: Q-Jet Question (Pacin'California)
Thanks Steve!
Anybody else with an opinion on this?
Old Nov 26, 2003 | 02:34 PM
comp's Avatar
comp
don't know the company but a fine idea to fix it if there isn't a shop to trust
around you
To Q-Jet Question
