i do remember someone saying that it would fit under a later model hood and not a 70 but with my scoop on there i think it may fit now.
i think that the main air box will be under the scoop and the throtle body will be under the org hood part (look at the pic to understand)
so what i am needing is a measurement from the front of the manifold where it meets the block to up to the hight of the tb and to the back of the tb so that i know the hight of it as well as it position realitive to the front of the block.
the deminsions on line just say that it is 10 1/2 inches but i can see in the pic that the tb drops down some
Check the race upgrade out, sounds like what I want to be able to use a wide band O2 and have it control the A/F ratio to whatever you want it be. :cool:
