Replacing Intake Manifold and....
Old Nov 29, 2003 | 07:46 PM
Chris69's Avatar
Chris69
Default Replacing Intake Manifold and....
...saw this grunge around all the valves.... So how bad is this?
Old Nov 29, 2003 | 10:22 PM
72Shark's Avatar
72Shark
Default Re: Replacing Intake Manifold and.... (Chris69)
You've got leaky valve seals. I had the same grunge on mine when I tore it down, and it was due to leaky valve seals. Easy fix though!! New seals will probably do the trick, unless your valve guides are severly worn. Then that would be more of a "major" fix for the heads. Hopefully seals only!!!
Old Nov 30, 2003 | 03:47 AM
comp's Avatar
comp
Default Re: Replacing Intake Manifold and.... (72Shark)
i agree with shark. take a time-out and see about it now (you're half way there now!)
To Replacing Intake Manifold and....
