Electrical help Please.
Old Dec 1, 2003 | 04:37 PM
Col-UK's Avatar
Col-UK
Default Electrical help Please.
You guys really know your stuff.
Thanks Baja216 for excellent web site for wiring diagrams http://iotech.no/corvette/index.htmNow for the prob! '80 with manual transmission. Starter not working. I have metered through wiring and found a relay? to the right of the gearshift stick It is a whitish colour with 4 connections -1 purple, 2 purple with white tracer and a black with white tracer. If I remove relay and bridge between the Purple and the purple/white furthest away on connector block- It Starts normally!! This relay not shown in wiring diagram, so what is it??
[Modified by Col-UK, 9:43 PM 12/1/2003]
Old Dec 1, 2003 | 05:04 PM
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Default Re: Electrical help Please. (Col-UK)
not sure but I'm guessing set belt relay, maybe neutral safety switch? :confused: :leaving:
[Modified by SnoDrgn, 4:06 PM 12/1/2003]
Old Dec 1, 2003 | 05:10 PM
Col-UK's Avatar
Col-UK
Default Re: Electrical help Please. (SnoDrgn)
I can email a picture if you like. You say neutral switch, I thought it was autos that have them and that manuals have a clutch switch? Is that correct?
Old Dec 1, 2003 | 10:32 PM
wombvette's Avatar
wombvette
neutral safety switch :iagree:
Old Dec 1, 2003 | 11:12 PM
Fleetwood's Avatar
Fleetwood
It may be an anti-theft relay,you will need to trace out the wiring to see where it goes.See if you can find a diagram on the anti-theft circuit.
Neil.
Old Dec 2, 2003 | 10:27 AM
SnoDrgn's Avatar
SnoDrgn
Really not sure. You can e-mail me a pic if you want and I'll host it for you.
Old Dec 2, 2003 | 02:28 PM
wombvette's Avatar
wombvette
You are correct. I missed the manual part.
Old Dec 2, 2003 | 03:13 PM
SnoDrgn's Avatar
SnoDrgn
Default Re: Electrical help Please. (wombvette)
Old Dec 2, 2003 | 07:16 PM
Col-UK's Avatar
Col-UK
Thanks for posting pics. Any ideas, or is it neutral safety / anti theft?
To Electrical help Please.
