82 headlight timing
Old Dec 3, 2003 | 01:34 AM
mannymen's Avatar
mannymen
Default 82 headlight timing
is there any way to adjust the opening and closing of my headlights on my 82? whenever i turn on my headlights, the left one opens up first. then after about 3-5 seconds, the right one pops up. is there any way to have them operate at the same time?
Old Dec 3, 2003 | 01:46 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: 82 headlight timing (mannymen)
my 1980 is the same way. It's a sign of leaking headlight acctuators or relays.
Old Dec 3, 2003 | 01:47 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Theres no way to make them go up and down exactly the same time. but it sounds like your having some leaks....
Old Dec 4, 2003 | 03:12 AM
duntovlives's Avatar
duntovlives
there is a small seal on the shaft of the actuator that will cause that problem. it will soon get to the point that u will have to "help" the light up. the seals (w/boots) are cheap to buy, and easy to install. 601-495 1968-82 Seal Kit, 2 seals & 2 boots, car set $39.99 http://www.madvet.com/shop?frame=4.249.1273 good luck :thumbs: :cheers:
To 82 headlight timing
