The Weakest Link
Old Dec 4, 2003 | 07:22 PM
Spook's Avatar
Spook
Default The Weakest Link
I was wondering what you guys would rate as the weakest link in a stock C3 setup when adding more hp and torque to the engine. In other words what would be the first thing to fail given an enormous amount of additional power. Or the first thing you would change additionally to the engine upgrades.
Old Dec 4, 2003 | 07:40 PM
Glensgages's Avatar
Glensgages
Default Re: The Weakest Link (Spook)
A small-block Chevy is a small-block Chevy (same goes for big-block cars, too); if over-stressed, the motor'll 'let-go', whether in a C3, or an Impala...
A Muncie, THM 350, or 400 is a Muncie, THM350, or 400; if abused, it'll give-up the ghost, be it in a C3, or a Chevelle.
In my opinion, the rear-end/axle-shafts is the weak-link, in stock configuration.
The IRS handles decently, but when adding enormous amount of additional power, if the tires 'hook' (especially during those 'STOP-LIGHT NATIONALS'), there are too many things that can go bad.
Just my $.02 worth...
Old Dec 4, 2003 | 08:03 PM
The Money Pit's Avatar
The Money Pit
I have three transmissions so far in mine,so my vote goes to the trans.Though not advisable I've run stock 350 lower ends to well into the 350hp range.I would have thaught the cast pistons would have let go,or the rods,but the General proved me wrong on many occasions. :chevy
Old Dec 4, 2003 | 08:06 PM
SharkPilot's Avatar
SharkPilot
Default Re: The Weakest Link (Glensgages)
I agree. Everything I have ever read says the same thing. The rear-end and stub axles are the weak links in the chain. The factory had those L88 mules that held together, so it is pretty strong back there. If I remember correctly, we're safe until we get up there past about 500HP.
There are quite a few parts available to build them up. I have read a few build-up articles in the magazines over the years.
It ju$t take$ lot$ of dollar$.
Best of luck,
SharkPilot :steering:
Old Dec 4, 2003 | 08:47 PM
aharte's Avatar
aharte
I think the half-shafts are usually the first things to fail. They're put under a lot more stress than most other components.
Old Dec 4, 2003 | 09:57 PM
Zack Wenning's Avatar
Zack Wenning
Default Re: The Weakest Link (aharte)
I replaced the u-joints in the halfshafts and on the driveshaft of my car with Spicers before I started making my engine more powerful. I hear that it's fairly common for a ujoint to "let go" and the results are not very pretty.
Are you considering running drag radials/slicks?
Old Dec 4, 2003 | 11:05 PM
mapman's Avatar
mapman
I was wondering what you guys would rate as the weakest link in a stock C3 setup when adding more hp and torque to the engine. ...
There will always be a "weakest link" no matter how much $$$ is put into the drive train. Perhaps you should deternine the easiest/cheapest thing to repair and have that be the "weakest link".
To The Weakest Link
