What engine is this?
Old Dec 5, 2003 | 03:10 PM
swifty777's Avatar
swifty777
Cruising
Default What engine is this?
Just bought a '71 454 4spd AWESOME! The orginal motor, sadly is gone and in it's place is what appears to me to be a small block 350. I've checked the engine block casting number (3970010) and casting date (D 14 9 or maybe 0 or 8?). The books I have indicate this to be a chevrolet 350 block. What gets me is the front stamp pad number V 04 29 XT. What the heck is an XT motor? Anyone out there recognize this?? The closest I've come to decifering an XT suffix is a late model Ponitac 301 (this is highly doubtful). There is no VIN on the pad so I doubt it's a Corvette motor. It does have the "double-hump" heads with the old L-82 finned aluminum valve covers. Any ideas what motor this might have come from?
Swifty- :confused: :confused: :confused:
Old Dec 5, 2003 | 03:22 PM
Fevre's Avatar
Fevre
Default Re: What engine is this? (swifty777)
That casting number was also used for the 69 Z28 302, you might be able to charge Dep to drool near it. :)
http://www.classictruckshop.com/castgm_smblock.asp
about 2/3 the way down the page you will find the casting numbers.
Old Dec 5, 2003 | 03:23 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
3970010 is the casting number on the small block that was original to my 71. Not sure what it came from, but could have been small block from another vette.
Old Dec 5, 2003 | 03:28 PM
Fevre's Avatar
Fevre
Default Re: What engine is this? (Fevre)
Here's another site that does not have it listed as a 302 but does have it as a vette, looks like the 70 LT1 370 hp:
1969-79 3970010 350 185 370 2 or 4 car, truck, Vette
The 185 370 are hp and the truck looks like the 185 and the vette looks like the 370
http://www.geocities.com/meanracing/...formation.html
Bet if I keep looking I can make it any motor you want. :lol:
[Modified by Fevre, 3:29 PM 12/5/2003]
Old Dec 5, 2003 | 03:32 PM
Mike Ward's Avatar
Mike Ward
Most of the 'X'series of engine codes are from Chev trucks. Yours is probably from a 1979 vintage. :cheers:
Old Dec 5, 2003 | 04:17 PM
Scooter70's Avatar
Scooter70
The 010 block is a high nickle block (IIRC) and can be 2 bolt or 4. As said above, they were used in everything. The motor that I just pulled from my car was a 2 bolt 010 block from a 73 Camaro.
Old Dec 5, 2003 | 05:12 PM
Hershey's Avatar
Hershey
Swifty, I would say that you have a 350 out of a 69 truck. As stated before, most of the X codes were trucks(c and K, 10 and 20) Also, after 69, Chevy started using 3 digit codes on the front pad. It may have started life as a truck engine, but it can be upgraded in the hosepower dept. just like any other small block. Enjoy it!! Hershey :chevy :chevy :chevy
Old Dec 5, 2003 | 09:37 PM
swifty777's Avatar
swifty777
Cruising
Default Re: What engine is this? (Hershey)
Thanks ya'll for your responses. Looks like that ## came froma variety of sources. I'm going to pull a valvelcover and get a serial number of one of the heads because I'm curious about them too. May also indicate what the CID of the block is if it's matched properly. Engine only needs to last until a suitable 454 can be prepared and "squeezed" in! :D
Swifty out-
To What engine is this?
