Force 10 brakes
Old Dec 6, 2003 | 10:15 PM
flynhi's Avatar
flynhi
Default Re: Force 10 brakes (killervette666)
KV666,
What does that setup weigh - what is the weight saving compared to OE?
Old Dec 7, 2003 | 10:52 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Force 10 brakes (flynhi)
Do they make a superlite 6 that will work on the rear calipers? Or could I put them in the front and use something like the dynalite.
Old Dec 7, 2003 | 11:29 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Force 10 brakes (Twin_Turbo)
But the bracket for the Dynalites in the rear is not just a square bracket, it has a good 3/8" offset.
Guru,
My recomendation is to use the 1.38" dia piston Dynalite in back and the superlite (4 or 6 piston) in front...
http://www.heidts.com YES
The 5,25 hole spacing on the dynalite caliper is the same as stock, the stock rear caliper has 5,25 also. Only the mounting ears on the DLIII are too short. The Integra has 5,25 spacing too, so a rear bracket for them is very easy, just a square plate like the heidts thing.
[Modified by Twin_Turbo, 5:40 PM 12/6/2003]
Old Dec 7, 2003 | 02:53 PM
Guru_4_hire
Cruise-In V Veteran
Default Re: Force 10 brakes (427V8)
OK I will keep that in mind for when I get enough money to redo my brakes :cheers:
what is the thickness of our rotors?
Old Dec 7, 2003 | 04:08 PM
427V8's Avatar
427V8
Default Re: Force 10 brakes (Guru_4_hire)
11.75" diameter
1.25" thick
Old Dec 7, 2003 | 04:19 PM
Guru_4_hire
Cruise-In V Veteran
thanx
