trans cooler install
whats the best way to install a transcooler(on a 73)-go directly from trans to cooler with both lines or go from trans to radiator to cooler and back to trans? i got a kit from a vendor at vette fest a few weeks back and understand theres different ways to do the install---also it seems to fit pretty good in frt of the air condt coils--is there a better place it fits??
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Go with the trans to radiator to cooler to trans route. In front of the radiator and behind the condenser coil is where I put mine, I saw a different type once that was like a tube with star fins, similar to an electronic heat sink. The guy mounted it above the air dam where the air comes in through the valence panel, looked really good.
