1979 Vortec 350
Old Dec 7, 2003 | 08:49 PM
79Brian's Avatar
79Brian
Default 1979 Vortec 350
I am in the process of rebuilding the 350 with vortec head and maniford and I have a few issues. First of all is the new style Valve covers. I would really like to keep corvette valve covers but I guess its not 100% nessassary. What years came with the center bolt patterns on vortec heads? Or what is a good aftermarket valve cover with the center bolt pattern? The second issue is the new vortec manifold is a little higher then the stock one. What carb and air cleaner will fit with the little space under the hood?
Thanks for the help
Brian
Old Dec 7, 2003 | 09:03 PM
EDDIEJ82's Avatar
EDDIEJ82
Default Re: 1979 Vortec 350 (79Brian)
1. I saw a kit that will let you run standard bolt pattern covers on a centerbolt head simple rail system summit or scoggin dickey i think
2. a drop base cleaner should work
Old Dec 7, 2003 | 09:41 PM
79Brian's Avatar
79Brian
Default Re: 1979 Vortec 350 (EDDIEJ82)
Old Dec 8, 2003 | 02:29 PM
American Boy's Avatar
American Boy
Hi,
I put the Edelbrock Performer and the original air cleaner. I just had to bend it a little to make it lower.
For the valve cover, I wanted to keep my original one so a machine shop drilled 4 hole and welded inserts. It's not costly compare to the adaptor that are sold at around 150$ if I remember correctly and you eliminate a chance of oil leak (2 gasket per side with the adaptor).
Here's a picture:
Stephan
[Modified by American Boy, 3:13 PM 12/8/2003]
Old Dec 8, 2003 | 08:10 PM
79Brian's Avatar
79Brian
looking good. So if I decide not to keep the original valve covers what year corvette can I get the center mount ones off of?
Old Dec 9, 2003 | 06:21 AM
djgrelli's Avatar
djgrelli
Just went throught the same thing with my 78. Wound up using a center bolt chrome plated alluminum with bowtie and K&N oval filter, nice setup. The Valve cover adapters are available from PacePerformance for $154.00 That's why I bought new covers. Their number is 1-888-748-4670 Part Number for the kit is 24502540.
To 1979 Vortec 350
