Beef up 1980 drivetrain
Old Dec 15, 2003 | 10:02 AM
Badvibe's Avatar
Badvibe
1st Gear
Default Beef up 1980 drivetrain
Have a 1980 vette with 434 cu small block.. 700 hp and need to know how to beef up the drivetrain to stand the preasure. have a 308 alluminum rearend but want to put 355 gear under her.. will any of the earlier cast iron housings bolt up to the exhisting mounts and how about the spindels and half shafts..? is any earlier stuff bigger and stronger? just want to know all I can learn before removeing whats there. Broke the universals off at the spindell at the track so got to at least beef those up as soon as possible. Any help would be great guys .. Thanks
Old Dec 15, 2003 | 11:46 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default Re: Beef up 1980 drivetrain (Badvibe)
Yes the cast iron will bolt up to your aluminum wing. You will ahve to change the side yokes, half shafts, strut rods, and spindle flanges. Yes the earlier stuff is stronger and you can get shafts from any 75-79 vette that are 3" shafts. I make Carbon fiber shafts that are stronger and lighter than any steel shaft. You can also move up to a 30 spline inner and outer axle set up. It can get kind of pricey but you won't have the problems you are running into now.
Here's the link for the 30 spline kit. http://www.vansteel.com/index.cfm?fu...&SubGroup=1878
You can ask Grandsport C3 for some picks of the carbon fiber 1/2 and driveshaft. I did an install on his 68.
Hope this helps you out :thumbs:
Old Dec 15, 2003 | 04:25 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I used Van Steel carbon fiber half shafts.. Those should be good to over 1000 HP... They are also 2 lbs/each lighter than the stock shafts and are much stronger... I already testet them at the track (running slicks) and they held up perfectly!!!
here's a pic of the oringal shafts...
[Modified by GrandSportC3, 4:29 PM 12/15/2003]
Old Dec 15, 2003 | 05:05 PM
78 Vette's Avatar
78 Vette
Default Re: Beef up 1980 drivetrain (GrandSportC3)
4,600.00 for both sides? :crazy:
Old Dec 15, 2003 | 06:30 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Default Re: Beef up 1980 drivetrain (Van Steel)
"Yes the cast iron will bolt up to your aluminum wing. You will ahve to change the side yokes, half shafts, strut rods, and spindle flanges. "
Dan you sure about that? If it will it's the first time I have ever heard of it. I would like to know if you can or not. Jim
Old Dec 16, 2003 | 09:01 AM
Van Steel's Avatar
Van Steel
Default Re: Beef up 1980 drivetrain (PROSOUTH)
Yes it will work. I've done it before. Here's a link to show the 30 spline set up in a 80 using the cast iron parts. This will kind of give you an idea of what it will look like. You just have to down size the parts if you don't go w/the 30 spline.
http://vansteel.com/photos/index.cfm...Thumbs&e=4&s=1
Old Dec 16, 2003 | 10:47 AM
PROSOUTH's Avatar
PROSOUTH
St. Jude Donor '05
I learn something everyday, You have shown me one that I had considered looking at making an adapter to accomplish. Had no idea it was a bolt in. Thanks Jim
To Beef up 1980 drivetrain
