Power steering pump
Old Dec 15, 2003 | 11:18 PM
greg7097's Avatar
greg7097
Default Power steering pump
Does any one have a photo of how it mounts on a 1970 small block car
I am installing steeroids on a non power steering car
a photo is worth a 1000 words
thanks
Old Dec 15, 2003 | 11:32 PM
Tyler Townsley's Avatar
Tyler Townsley
Default Re: Power steering pump (greg7097)
Find yourself a Toyota MR 2 electric power steering pump. I picked one up for $150 and is my next project.
Tyler
Old Dec 16, 2003 | 08:36 AM
greg7097's Avatar
greg7097
Default Re: Power steering pump (Tyler Townsley)
Thanks but i already have a stock pump and brackets. I just dont know how it goes on. Though i wish i knew of that before i bought them.
Old Dec 16, 2003 | 10:15 AM
SCCACFC's Avatar
SCCACFC
If you have the correct brackets, both brackets have 2 holes apx. 2 in. apart 2 bolts hold both of them on. They will line up with two holes on the front of the cylinder block (left lower). The one with the adjuster goes on first and is sandwitched on by the second bracket (the one that looks like a J ). Once you hold the first bracket up to the holes on the block you will see that the other mounting point is one of your motor mount bolts.
Once the brackets are on you will need a stud-bolt that screws into the back of the pump, these are hard to find because the hex head must be thinner than a normal stud-bolt.
Once you have the correct parts its not hard to install really.
Make sure your p\s lines don't rub the center link makes a big mess at the worst time. :U
Old Dec 16, 2003 | 10:32 AM
greg7097's Avatar
greg7097
Default Re: Power steering pump (SCCACFC)
Thanks!!!! that is what i needed to get me started.... its hard to figure out when you have never taken a good look at it or takend it apart
Old Dec 16, 2003 | 10:35 AM
Twin_Turbo's Avatar
Twin_Turbo
Tyler
Better idea, check on ebaymotors.com and get a sweet or krc pump and mounting plate.
Old Dec 16, 2003 | 10:44 AM
Jim Shea's Avatar
Jim Shea
I just sent you two AIM sheets with the small block power steering pump and brackets.
Jim
To Power steering pump
