Ref. Homemade offset trailing arms
Old Dec 16, 2003 | 09:25 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default Ref. Homemade offset trailing arms
http://forums.corvetteforum.com/zerothread?id=551300
I found this thread concerning homemade offset trailing arms. I'm thinking about taking it one step further by modifying the trailing arm by relating the location of the spring end bolt were is attaches to the spring; move closer towards the centerline of the car. I understand that it is possible to order composite springs to length, shorter. This idea would increase the space between the spring and the wheel/tire and decrease the curvature of the spring, since it is shorter thus also lowering the car. What do you guys think?
Old Dec 17, 2003 | 06:17 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Re: Ref. Homemade offset trailing arms (74 vert)
Norval modified his stock trailing arms, hopefully he'll chime in ;)
Oops, guess I shold have checked the link 1st :bb
Here's a 4 link installed in a C3
And some more:
[Modified by SmokedTires, 9:00 AM 12/17/2003]
Old Dec 17, 2003 | 07:03 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Ref. Homemade offset trailing arms (SmokedTires)
And some more:
[img]mhtml:http://www.corvettefaq.com/c3/SuspensionObservations.mht![/img]
[Modified by SmokedTires, 6:35 AM 12/17/2003]
That's not a 4 link in a C3, it's a C4 with heim ended rods for the dog bones, brembo calipers and coil overs.
Old Dec 17, 2003 | 07:42 AM
norvalwilhelm's Avatar
norvalwilhelm
Look at the picture in the link. The spring perch has been moved over.
A steel spring is easy to shorten.
Springs are not that hard and with a sharp drill bit , slow speed and cutting oil it is easy to cut the end off and redrill.
Old Dec 17, 2003 | 11:51 AM
SAC's Avatar
SAC
What's up with the dual calipers? Or is this some kind of demo?
Old Dec 17, 2003 | 01:52 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Re: Ref. Homemade offset trailing arms (SAC)
I've seen that before and never understood either... just for more braking power? Not really the best way to go about that. Or is it for use as a parking brake?
Where can you order composite springs to length??
Old Dec 17, 2003 | 09:59 PM
74 vert's Avatar
74 vert
Default Re: Ref. Homemade offset trailing arms (RUXperienced)
I seem to remember reading a post of someone asking a vender about delivery of a shortened spring. I just can't remember who. I'm searching for that thread.
Old Dec 17, 2003 | 10:21 PM
stinky's Avatar
stinky
The smaller one on the right looks like a parking brake but then again....?
[Modified by stinky, 9:23 PM 12/17/2003]
Old Dec 18, 2003 | 07:45 AM
norvalwilhelm
I asked for a shortened composite spring. One of the vendors was giving a great deal so I wanted in but with a few inches shorter. The cost for the shortened spring was quit a bit higher.
I ended up going coil over.
Old Dec 18, 2003 | 07:53 AM
Twin_Turbo's Avatar
Twin_Turbo
read what I wrote above, it is NOT a C3, it's a C4. The brembo caliper takes care of the braking but since the late C4s have the parking brake as part of the original calipers you must retain them. The early ones had a drum style setup like we do. So, the brembo caliper in that pic is for braking and the other one is the parking brake now.
To Ref. Homemade offset trailing arms
