Help identifying this…
Old Dec 20, 2003 | 03:44 PM
Skyhigh82's Avatar
Skyhigh82
Default Help identifying this...
Having some trouble with my headlights, found this with the other end broken off. Can I replace it and not the whole harness? And what is it?
[Modified by Skyhigh82, 3:46 PM 12/20/2003]
[Modified by Skyhigh82, 11:08 AM 12/21/2003]
Old Dec 20, 2003 | 04:01 PM
GDaina's Avatar
GDaina
Default Re: Help identifying this… (Skyhigh82)
looks like an inline resistor....if you can match it, you can replace it.
Old Dec 20, 2003 | 11:55 PM
Skyhigh82's Avatar
Skyhigh82
Is it a resistor or a capacitor?
Old Dec 21, 2003 | 02:47 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
it looks like a capacitor and the voltage and mfds should be listed on the side. :chevy
Old Dec 21, 2003 | 04:42 AM
Fleetwood's Avatar
Fleetwood
It does look like a capacitor,although what it does I have no idea.Can't see why you would need an inline cap. in the headlight circuit.
Where does the wire go to,& where does it come from?
Neil.
Old Dec 21, 2003 | 04:58 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Help identifying thisĂƒÂ‚Ă‚Â… (Fleetwood)
that is not a stock 82 part, the only place where you will normally find something like that is the tach filter.
Old Dec 21, 2003 | 08:51 AM
79VetteMike's Avatar
79VetteMike
Where exactly did you find it and what exactly was it connected to? If it was just connected to a wire, what color was it? It could be a resistor or a capacitor.. from the looks of it it could even be an inductor. If you can tell me what it says on the side, I can tell you what it is. Also, what is that little thing at the end that looks like a connector?
Old Dec 21, 2003 | 10:27 AM
Skyhigh82's Avatar
Skyhigh82
Default Re: Help identifying thisĂƒÂ‚Ă‚Â… (Skyhigh82)
After disconnecting the other end, which was grounded, it looks like it goes to the horn. The marking on the capacitor is (.33 M100). The black wire is grounded to the frame.
[Modified by Skyhigh82, 10:29 AM 12/21/2003]
Old Dec 21, 2003 | 11:04 AM
Fleetwood's Avatar
Fleetwood
Default Re: Help identifying thisĂƒÂƒĂ‚Â‚ĂƒÂ‚Ă‚Â… (Skyhigh82)
How many horns do you have,you should have two up front.
Old Dec 21, 2003 | 05:27 PM
Skyhigh82's Avatar
Skyhigh82
Default Re: Help identifying thisĂƒÂƒĂ‚ÂƒĂƒÂ‚Ă‚Â‚ĂƒÂƒĂ‚Â‚ĂƒÂ‚Ă‚Â… (Fleetwood)
Two, one on each side. The rt. side has the same capsistor between the ground and green wire.
Old Dec 22, 2003 | 12:23 AM
Fleetwood's Avatar
Fleetwood
Default Re: Help identifying thisĂƒÂƒĂ‚ÂƒĂƒÂ‚Ă‚Â‚ĂƒÂƒĂ‚Â‚ĂƒÂ‚Ă‚Â… (Skyhigh82)
There is no reason for either of them to be there,just remove them both & wire direct to the horns.
Neil.
Old Dec 22, 2003 | 07:06 AM
Skyhigh82's Avatar
Skyhigh82
Will that ground out my horns? Or create a short?
Old Dec 22, 2003 | 07:30 AM
Fleetwood's Avatar
Fleetwood
Default Re: Help identifying this (Skyhigh82)
No,all you will be doing is restoring you horn circuit back to how it should be.
The green wire comes from your horn relay,When you push the horn button you are in fact grounding the one side of the horn relay coil,causing it to close the contact,supplying voltage via the green wire to the horns,the horns in turn need to be groung to earth to complete the circuit.
Would suggest you get a good wiring diagram to help you follow indivual circuits out.
Neil.
To Help identifying this…
