X-pipe and Crankcase evac system
Old Dec 20, 2003 | 04:07 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default X-pipe and Crankcase evac system
Do x-pipes and a crankcase evacuation system not mix well? Car has been running fine. Install crankcase evacuation system....still running fine. Just got back from putting in the x-pipe and it's smoking like a sonnovabitch now!!! Like, so bad it's embarrasing. Seems to do it worse when I'm decelerating and even smokes a bit just sitting at a light.
Please help!
Old Dec 20, 2003 | 06:25 PM
flynhi's Avatar
flynhi
Default Re: X-pipe and Crankcase evac system (tshort)
What do you mean by crankcase evacuation system? A PCV system or a Winston Cup/Circle track type system?
Old Dec 20, 2003 | 06:27 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: X-pipe and Crankcase evac system (flynhi)
It's basically a PCV valve with a hose attached to it that goes into the exhaust just behind the collectors. It helps relieve crankcase pressure on high-pressured engines. Without it, the pressure builds up so much in mine that oil leaks start showing up.
You see them a lot on drag cars but not often on street cars.
Old Dec 20, 2003 | 11:00 PM
gkull's Avatar
gkull
Mr. Short An evac system should only be sucking oil mist and blow bye.
So if you have blue smoke Do a leak down test and see if you have other problems.
Old Dec 20, 2003 | 11:03 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: X-pipe and Crankcase evac system (gkull)
Has the oil consumption increased since the install of the Crankcase Evac System?
Old Dec 21, 2003 | 12:30 AM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: X-pipe and Crankcase evac system (Eddie 70)
Well, I've only driven about 15 miles or so since it was installed so it's hard to say.
Old Dec 21, 2003 | 03:02 AM
tshort's Avatar
tshort
CI 7-8 Veteran
I think I may have solved it. I had just put on a chrome brake master cylinder cover on yesterday. Got up under the car and noticed fluid running down the crank evac hose on drivers side. Turns out, the fluid is brake fluid that was seeping thru the master cylinder cover. So it looks like somehow the brake fluid was seeping in right where the crank evac hose meets the tube in the header collector and I was burning brake fluid. I put back the old cover on and I'll have to wait until tomorrow to test. Wish me luck.
Old Dec 21, 2003 | 05:32 AM
Spook's Avatar
Spook
Haha... I hear you travis... I have one of those damn chrome covers (previous owners choice) on my mc and its tricky to get it to seat up just right... plus maybe I am on and off the brakes a little to fast sometimes... aint nuttin wrong with that though.
Old Dec 21, 2003 | 09:03 AM
flynhi's Avatar
flynhi
I had the same problem a while back. I solved it by adding a second rubber gasket and slightly bending the wire hoops that tension the cover down.
The chrome cover from GM fits much better than other aftermarket covers.
Old Dec 21, 2003 | 02:38 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Well, after the test run I found I'm not so lucky. It still smokes. Actually, I was fooled for a while because aparently it only smokes when the engine is warm. It doesn't smoke upon first startup.
I checked the oil level and it actually seems a little high. I must have put a little too much in last time and checked it before it all drained down.
Is it possible that the smoke is coming from having my oil level too high and more oil than normal is blowing out the valve cover vents? With the exception of some more carb tweaking, the engine seems to run fine.
Old Dec 21, 2003 | 03:34 PM
Ryan77's Avatar
Ryan77
I had the same problem in my old motor Travis, and it was because I added too much oil. I let it burn it off and it soon there was no more smoke :crazy:
Old Dec 21, 2003 | 03:53 PM
Spook's Avatar
Spook
Default Re: X-pipe and Crankcase evac system (Ryan77)
I wouldn't jut let it burn out especially depending on how much is too much. Just drain off a little from the pan run your car a good time/distance and see what its all got to say.
I don't know you sure your headers still dont have some brake fluid on em. Seems to me the engine would be darn close to burning up oil from the get go if it was the evac system. What kind of lines does it use and where does it hook into the ex. pull?
Old Dec 21, 2003 | 04:16 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Do your valve covers have baffles? You might be pulling oil right out of the rocker spray.
Old Dec 21, 2003 | 11:39 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: X-pipe and Crankcase evac system (AlwaysWave)
I cleaned the brake fluid off real well and even re-did the connection with some teflon tape. Yes, the valve covers have baffles. I'm going to see if I can drain some of the oil out without making a huge mess and take it from there. I'll let you guys know what happens in case anyone else is possibly experiencing something similar.
I don't have any pics of the system but it's the same one that Olivier (GrandSportC3) put on his and he posted a few pictures.
:cheers:
Old Dec 22, 2003 | 04:26 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Please help!
I've never dealt with a x-pipe.. In my case - the smoking disappeared after I installed the crankcase evac. system..
BTW - there shouldn't be a PCV valve in the breathers.. Other than foam - there should be nothing else in them breathers...
[Modified by GrandSportC3, 4:27 PM 12/22/2003]
Old Dec 22, 2003 | 04:31 PM
GrandSportC3
After I installed my evac. system - it was still smoking until I drove the car a little harder... Driving the car harder caused more vacuum to build up and push the rings into a better seat... Try do drive the car a little harder for a few miles and see if the smoking stops.. That's the way it worked for me.. The evacuation system doesn't do too much at lower RPM (low vacuum)...
To X-pipe and Crankcase evac system
