[Pics] finished suspension (Dial up explosion)
Old Dec 23, 2003 | 08:04 AM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default [Pics] finished suspension (Dial up explosion)
OK as promised, I said I was going to give you play by play on the spacer removal for my car.. well I got too involved in the project that I kinda forgot to snap pics along the way, but I did get a couple of good shots.
I'll start with the before pics (with an engine in the car mind you)
Here is how the car sits now remember.. I have no engine in the car so my friend decided to put a little bit of wieght on the front.. he's 180lbs and I know a 350 with cast heads weighs a LITTLE more then that.
is it me or does it look the same as it did with an engine in there?
last pic is the spacers..
I'd say they look to be about 1.5-2 inches tall.. so I think when I finally DO get an engine in the car, I'll be pretty damn low, which is what I am going for
Old Dec 23, 2003 | 09:04 AM
Madmikeee's Avatar
Madmikeee
From: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
Default Re: [Pics] finished suspension (Corz)
Lookin good Cor, Just remember not to go TOO low if you plan on driving in MASS. I swear they are installing potholes on a daily basis around here :banghead: :cuss :cuss :cuss
Old Dec 23, 2003 | 09:05 AM
Corz's Avatar
Corz
Default Re: [Pics] finished suspension (Madmikeee)
thanks... I dont plan on going through mass anytime soon.. Then again.. CT isnt that far off on the pot hole situation :banghead: :banghead: :banghead:
Old Dec 23, 2003 | 09:38 AM
Twin_Turbo's Avatar
Twin_Turbo
I think it's still on the high side, even with the engine removed and your buddy sitting on it. Are you certain you have the springs installed correctly? I hope it will be lower when you reinstall the engine & stuff, it's not much fun having to take the whole suspension apart again.
Old Dec 23, 2003 | 12:58 PM
Corz's Avatar
Corz
Default Re: [Pics] finished suspension (Twin_Turbo)
I think it looks high because of the angle of the picture.. I'll try to get a better one this afternoon with him and my roomate (275lbs) standing on the crossmember :jester
Old Dec 23, 2003 | 03:40 PM
frank0075's Avatar
frank0075
looks way too high!! Better check your spring installation! I don't think the engine will make up the difference.
Old Dec 23, 2003 | 07:34 PM
Corz's Avatar
Corz
Default Re: [Pics] finished suspension (frank0075)
springs are fine.. I've done this before. I know what I'm doing
Old Dec 23, 2003 | 08:06 PM
PRNDL's Avatar
PRNDL
Spacers? Damn! I thought those were your old tires! :lol: MJ
Old Dec 23, 2003 | 08:21 PM
Corey_68's Avatar
Corey_68
Default Re: [Pics] finished suspension (MNJack)
I think she'll sit just fine. :thumbs:
Old Dec 23, 2003 | 10:11 PM
frank0075's Avatar
frank0075
Default Re: [Pics] finished suspension (Corey 68)
I'm not so sure you know what you are doing!!!!!!
Old Dec 23, 2003 | 10:35 PM
Corz's Avatar
Corz
:skep: you can shut up now. I DO know what I'm doing, I'm probably better at it then you are.
http://temp.corvetteforum.net/c3/cor...e/103_0334.jpg
http://temp.corvetteforum.net/c3/cor...e/103_0337.jpg
thats with my 250lb roomate on the car.. if you want, I'll have someone else take the picture while I stand on it to just to prove you cockbites wrong
[Modified by Corz, 10:35 PM 12/23/2003]
Old Dec 23, 2003 | 11:08 PM
frank0075's Avatar
frank0075
:rolleyes: :rolleyes: :rolleyes:
Old Dec 24, 2003 | 08:01 AM
Jasonty's Avatar
Jasonty
I'm thinking a 350 with all the accessories and whatnot will make it sit quite a bit lower. I wouldn't stress if I were you, it's still a nice car. ;)
Old Dec 24, 2003 | 10:30 AM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Re: [Pics] finished suspension (Jasonty)
I think you'll be fine once you drop the engine in. It looks just like the old 77 did prior to the engine rebuild, well guess we will see. What's the spring rate??
Old Jan 5, 2004 | 10:14 AM
Madmikeee's Avatar
Madmikeee
Cruise-In X Veteran
St. Jude Donor '06
She still looks a bit on the high end but I am sure once the block and all the accessories are back in she will sink down quite a bit. :cheers:
Old Jan 5, 2004 | 11:37 AM
ZD75blue's Avatar
ZD75blue
Looks nice :cool:
Old Jan 5, 2004 | 12:59 PM
markdtn's Avatar
markdtn
Default Re: [Pics] finished suspension (ZD75blue)
Looks OK to me. The engine, accessories, fluids, etc will bring it down a good bit.
To [Pics] finished suspension (Dial up explosion)
