gear change
Old Dec 25, 2003 | 01:59 PM
terry82's Avatar
terry82
Default gear change
i would like to change the rearend gears in my 82[3.55] do you have to spread the housing?
Old Dec 25, 2003 | 08:17 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: gear change (terry82)
I have done a number of gear changes over the years including 3 or 4 on my 75 and I have never needed to spread the housing. I get a snug fit on the shims and then add .005 per side for preloading. I install the thin shims first then tap the biggest one with a rubber mallet.
Old Dec 27, 2003 | 11:06 AM
terry82's Avatar
terry82
Default Re: gear change (norvalwilhelm)
norvalwihelm,thanks for your response.would also like to know your opinon on, if there is anything differnet or that we should look for on a corvette gear change than what we would do on any chevy gear change?
Old Dec 27, 2003 | 12:14 PM
ram82fire's Avatar
ram82fire
The alloy housings used on the 82 models will grow when the gear oil temp rises , it is good practice to spread them when rebuilding . The cast iron units can be done as norval explained in his post with little or no problems.
gman
Old Dec 28, 2003 | 04:25 PM
norvalwilhelm
terry82 I have never done a aluminum case, only cast iron but mustang vette they are all the same. The only thing I have started doing is not using the crush sleeve and going to a solid spacer.
Old Dec 28, 2003 | 04:55 PM
MIKER's Avatar
MIKER
I had to spread the aluminum housing to remove and install the carrier. The Dana 44 does not use a crush sleeve.
It was nice to know that forum members like Norval were ready to provide tech assistance when I did my gear swap.
ram82fire's reasoning for spreading was the first I've heard on this but it makes perfect sense. :thumbs:
To gear change
