Fuel sender unit.
Old Dec 26, 2003 | 02:27 PM
stingraymax's Avatar
stingraymax
Default Fuel sender unit. URGENT
I am going to do a frame off resto on my 75 vetteand have a question concerning the sender unit in the tank.
Since I will be taking everything out would it be wise to replace the sender unit by a new one ??
The old one is still working fine but I don't know if I should replace it while I can or leave it alone...
I can get a new one for a good price +/- 80$
Give me your toughts
[Modified by stingraymax, 8:49 PM 12/26/2003]
Old Dec 26, 2003 | 03:49 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Fuel sender unit. (stingraymax)
My old sending unit started leaking.. so I replaced it.. It's a good idea to replace it if it hasn't been replaced in a long time.. It's easy to do it..
Old Dec 26, 2003 | 04:00 PM
Bill Oxley's Avatar
Bill Oxley
Default Re: Fuel sender unit. URGENT (stingraymax)
IMHO, with frame off, replace EVERYTHING that you can reasonbly afford. You won't regreat it later. The labor of "going back" isn't worth the "difference"
GL!
Old Dec 26, 2003 | 10:12 PM
markdtn's Avatar
markdtn
Default Re: Fuel sender unit. URGENT (Bill Oxley)
Even if you don't replace the sender at least replace the gasket. Once they dry out, they leak. Well at least 68-74, I guess with a 75 I'd leave it alone.
[Modified by markdtn, 9:13 PM 12/26/2003]
Old Dec 27, 2003 | 06:04 AM
hunt4cleanair's Avatar
hunt4cleanair
Default Re: Fuel sender unit. (GrandSportC3)
I'm assuming you have an early C3 with the sending unit mounted from the button. He's got a 75 and I think by then the sending unit was incorporated into the gas tank fuel filler and mounted from the top.
Old Dec 27, 2003 | 08:01 AM
stingraymax
Default Re: Fuel sender unit. (hunt4cleanair)
that is correct the sending unit is on top of the tank.
To Fuel sender unit.
